Old 1st May 2008, 07:10 PM   #1
st_eloi is offline st_eloi  Netherlands
Default Material and finish questions
Hello,
I am planning to build a pair of mFonkers but I am unsure as to which material and finish to use.
At work we have lots of really nice oak, ideally I would like to use solid boards finished with oil. With the size of the enclosure, and the knowledge of the wood guys (I'm a metal worker), I think I can avoid undue stress and cracking etc.
The other option is to use BB ply. We have a really good paint shop at work, as we build furniture, so I could have any finish I want. Is there anything you guys have wanted to try but have lacked the knowledge or equipment / paints to try?
I guess what I am asking is; if you had the chance to use pretty much any material or finish to a high standard, what would you go for?
I'm sure I am probably underestimating the resources available to you, but if not, what would you go for?
David
Old 1st May 2008, 10:24 PM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Personally, I would like to have had available at one time or another....an inch and a half of void free plywood (14 ply?)....birch...I do believe it would make a superior 'panel' to construct a loudspeaker.
Note , I don't care about the weight of a loudspeaker.
________________________________________Rick...... .....
Old 2nd May 2008, 12:46 AM   #3
I like to build an inner box (glued and screwed) out of 3/4" MDF.
Then I glue and screw the outer panels to the inner box. I prefer a high quality plywood for the outer panels -- no veneering, which is a pain.
For the front baffle I like to use real wood, with a piece of 3/4" MDF glued and screwed to the back of it.
The solid wood front panel means no veneering of rounded corners.
JJ
Old 2nd May 2008, 02:35 AM   #4
tilroh is offline tilroh  Australia
Send a message via Yahoo to tilroh
I'd finish the solid wood with 30 coats of marine varnish followed by a coat or two of satin.
Old 3rd May 2008, 09:58 PM   #5
Andersonix's Avatar
I think it might look nice to finish a curved speaker and the front wall in the same natural grass wallpaper (or carpet the speaker the same as the floor, but this would have an unfortunate similarity to cat scratch furniture). There are also fake metal wallpapers that might suit the right decor.
Also gestating on ideas for molding or casting an Orion in concrete or synthetic stone or marble.
Old 4th May 2008, 12:27 AM   #6
mwmkravchenko's Avatar
Default What dreams are made of?
I've built quite a few boxes over the years. The ones that stood out from the rest consisted of a oval tube used for concrete pillars enclosed in a box with the resulting voids filled with sand. The baffle would be at least 1 1/2" thick using BB. Built like ã battle ship with no real sound of their own.
Mark
Mark
something to finish mdf paulfk Multi-Way 14 14th March 2009 02:04 PM
Does anybody know how to get this finish? wrl Multi-Way 177 30th January 2008 09:15 AM
Help me finish up this SET project (multiple questions / ramblings) zobsky Tubes / Valves 1 2nd October 2006 04:01 AM
Newb Questions, looking for good learning material jmartinson Chip Amps 5 10th May 2003 11:57 PM
Finish Aleph 2 "but questions" jeclk Pass Labs 8 15th February 2003 09:58 AM
Page generated in 0.08876 seconds (73.02% PHP - 26.98% MySQL) with 10 queries
