2 way xoover for scan speak 18w4531 and D2904/7100
Old 1st May 2008, 11:41 AM   #1
danyele is offline danyele  Italy
Default 2 way xoover for scan speak 18w4531 and D2904/7100
Tweeter
Woofer
For this speackers we have a project for a 2 way xoover?
Old 1st May 2008, 11:52 AM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
This one from Tony Gee is about as close as I've seen.
http://www.humblehomemadehifi.com/Optimo.html
Old 1st May 2008, 12:03 PM   #3
The tweeter isn't the same.
It's possible to replace the Optimo tweeter (D2904/7000) with the D2904/7100 without change the xoover?
Old 1st May 2008, 12:20 PM   #4
Inductor is offline Inductor  Portugal
Inductor's Avatar
They are very similar indeed. But Tony Gee' it's a TL box with a series xover, if that's what you are looking for. (vs. BR and parallel xovers)
Old 1st May 2008, 12:25 PM   #5
Isn't possible to use this xoover with a reflex box?
At the xoover point (2500 hz) the renspose of a woofer in TL or reflex must be the same.
Old 1st May 2008, 12:51 PM   #6
dublin78 is offline dublin78  United Kingdom
I have the 18W4531 and the R2904/70000.
I used Tony Gee's Optimo XO in a reflex box. It was not much better that the AOS Studio 35BR that I was not happy with.
I am building the Optimo TL cabinets as we speak. Work and wedding plans are interfering though. I am expecting a totally different result. The TL should add to the midrange quality also.
Old BR cabs:
TL cabs in progress:
Old 1st May 2008, 12:52 PM   #7
rabbitz's Avatar
Without modelling it, shouldn't be too far off and might just have to tweak L1, R3, R1. I don't know the difference in behaviour of these tweeters even though the specs look similar.
Should work OK in TL or BR IMO but as with all crossovers, they need final tweaking.
Old 1st May 2008, 12:58 PM   #8
P.S. If you decide to go down the TL route, and have not bought your tweeters yet, Tony has a XO revision that allows you to use the Vifa XT25TG30-04. Just change R1 to 1Ohm. The Vifa is tons cheaper.
Old 3rd May 2008, 08:45 AM   #9
rabbitz's Avatar
dublin78
Without completely redesigning the xo for your BR box, try reducing L2 to 0.56mH or R1 to 3R9 and see what happens to the mids. The inductor change should be more beneficial than the resistor change.
Old 3rd May 2008, 10:49 AM   #10
Rabbitz: Thanks I will bear that in mind, but I already have a set of AOS designed BR crossovers, as well as a pair of Tony Gee's Optimo crossovers. The bass reflex cabs are already being used with different drivers (with a good result), and I have nearly completed my TL cabs for the Scanspeak drivers. I will let you know the results.
2 way xoover for scan speak 18w4531 and D2904/7100Hide this!Advertise here!
Difference between Scan Speak 18w4531 and 18w4831 danyele Multi-Way 12 25th April 2017 05:38 AM
FS: Pair Scan-Speak D2904/7100, (1) AirCirc & (1) AudioTechnology 15H tf1216 Swap Meet 24 13th July 2009 01:49 PM
Xoover HELP: 2 way D2905/9900 + 18w4531 (Scan Speak Revelator) danyele Multi-Way 0 27th January 2007 12:07 PM
Look for a pair of Scan-speak 7100 tweeters tf1216 Swap Meet 4 8th December 2006 10:38 PM
Copyright ©1999-2017 diyAudio
