Bed base as a big sub?
Old 10th March 2003, 07:12 AM   #1
DPW666 is offline DPW666
Default Bed base as a big sub?
for quite some time the idea of making sub as a bed base has been in my head. My matresses are double size (6'x3') and wanted to use maybe 2 or 3 15" woofers. I would make it as heavy as possible with 1" thick MDF and lots of bracing so that thing won't move from there. This way I could have a real big sub without using valuable space since the bed is already in my room. Is this a good idea or am I just being silly? I was thinking of doing it as a transmission line but it would be the first time for me as I never built one before. Or maybe just go with the traditionnal vented box.
Old 10th March 2003, 08:01 AM   #2
gpapag is offline gpapag  Greece
gpapag's Avatar
It is a great idea indeed. Take care of the bracing though. If you build it as a transmission line, the "channeling" will serve also as bracing. But with so large volume why are you thinking of bass reflex? If not for transmission line, better go for sealed enclosure.
The only drawback i can see is, that after you will build it, you will spend all your time in your bedroom listening to the music (lucky you!)
George
Old 10th March 2003, 08:10 AM   #3
Nappylady is offline Nappylady  United States
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
(if this post needs to be deleted, SO BE IT!)
Can you imagine what fun sex would be with a bed subwoofer???
Old 10th March 2003, 08:24 AM   #4
lawriebuck is offline lawriebuck  Australia
Just Lie there.....
Old 10th March 2003, 10:39 AM   #5
Brett is offline Brett
Brett's Avatar
Default How about this?
Gives a new perspective to getting horny in bed.
[sorry, I've lost the text file with all the attributions in the HDD crash a while back. I beleive the owner is from Scandanavia. I'll try to find details]
Old 10th March 2003, 04:04 PM   #6
ksl is offline ksl  Estonia
ksl's Avatar
Send a message via MSN to ksl
but how about the wicked one design? http://www.decware.com/whorn.htm
make a lot of them!!
blue color
Old 10th March 2003, 04:18 PM   #7
Pan is offline Pan  Sweden
Actually I have made it the other way around.
I have a kingsize waterbed with a big volume under the matress, a couple of hours of work turned it into a bass absorbent
I drilled a bunch of holes in the side panels and stapled fabric and fiberglass to the inside for damping and broadening of Q.
He he..
When I did it I had the bed (obviously) in the listening room, now it is not in the direct listening room but still my apartment is "open" and the bed does probably a little good anyway.
/Peter
Old 10th March 2003, 06:02 PM   #8
Nappylady's Avatar
"getting horny"--I can't believe I didn't see that one coming.
Old 10th March 2003, 07:20 PM   #9
haha you guys crack me up! Yeah I didn't even think about about a sealed enclosure! With an enclosure that large it should give me a nice flat response tuned real low. Perfect! That "X" horn desing is a little bit to wicked for me I think lol. The bed could also be used as a good body massager. Think of all the possibilities!
My bed room is VERY small (12' long by 12' large by 6.5' high) but walls are made of concrete and damped with special material that I don't remember the name. I want to build this sub for SPL utilities like for home theater or to impress my friends . Quality wise I already have 2 boxes I built not long ago using high quality 12" drivers that has alot of chest thumping bass but almost no sub. The boxes are tuned to 45hz and cut at 60hz so I am missing alot on the low.
Anyone has suggestions for drivers? Like I said I want maximum SPL. I will be using DIY amps that I will build after I have the boxes so wattage can be anything. Maximum external dimensions will be about 72" x 36" by 17". That would give me about 23 cubic feets of internal volume without any bracing or anything.
Old 10th March 2003, 08:48 PM   #10
Nappylady's Avatar
Drivers?
Look at this page:
http://madisonspeakers.netfirms.com/woofers.htm
I'm using Sigma 15's in my PA system right now, and I must say that they SUCK HORRIBLY, SPL-wise. I wish I'd bought the better ones.
I'm sure, however, that the Executioner line would do what you needed. All the 15"+ Executioners are 100 dB+ efficient. (Take 3 dB off if you put it in a sealed box--I learned this the hard way!)
The ones at the very bottom, the "Future ExecutionerX 15 and 18", are very exciting to read about, and I would LOVE to see some of those in a horn-loaded configuration... I'll bet you'd have room for that under your bed!
Whatever you decide, let's see some pictures as you're building it!
And lemme know whereabouts you are so when you get it done I can drop by for a massage.
Bed base as a big sub?Hide this!Advertise here!
Base Stoppers lumanauw Solid State 72 22nd September 2010 03:30 PM
Best base for top CD transport emw Digital Source 9 24th November 2005 09:59 PM
What DO YOU base your next project /needs on ??? JinMTVT Multi-Way 21 18th November 2005 12:54 AM
base cavity? anonymoose Multi-Way 6 11th June 2005 06:49 AM
base for amp karma Tubes / Valves 7 18th June 2004 04:03 AM
