I'm new here - go easy ...
My father built a pair of ridiculously powerful speakers back in the early 80's and I've always wanted to follow suit and build my own set. However, I'm an avid movie watcher and love surround sound. As dominating as his speakers are, they simply aren't meant for a balanced surround system.
I would like to build a 7.1 system to include a 12" sub and floor standing fronts. Is this something that I should just buy complete? (Klipsch, JBL, etc) Is building a surround system simply not something one should do?
I'll be hooking up whichever speakers I go with to an Onkyo SR875 receiver. Thanks for any and all helpful comments.
Are you planning to wall mount this set up or can you use floor stand system?
How big is the room this system is going into?
Do you have a unlimited supply of money?
Are you farmiliar around a wood working shop?
Do you have access to wood working tools?
I brow a $4,000.00 table saw that can handle a 4'x8' sheet of mdf.
I can tell you from experience that if you have to purchase your tools you will have no money savings diying one set of speakers. Try a expert speaker designer that has tried and tested designs. Zaph is a trustworthy designer that has attention to detail like none other. He posts his designs on a web site for all to use free.
John "Zaph" Krutke's Audio Projects and Driver Tests
http://www.zaphaudio.com/index.html
Not true. If your cabinets are square and you get your wood cut to size at the lumber yard, all you will need is a router to trim the sides and flush mount the drivers. Thanks to the chinese you can buy an excellent router at a very reasonable price now. As for finishing the speakers, you can sand by hand or borrow something like an electric sander off a friend, or rent one for a day.
There are many different possibilities for your project. Try Parts Express to start with, or Google for known diy designs. You can buy kits, or assemble the parts yourself. Just make sure that you follow a proven design and crossover. These will blow away any of the high street offerings.
DIY subwoofers are very simple and may be a good place to start.
Tons of stuff on the web.
Good luck.
dublin78
not true ??????????????????????? As in Im lying?
The purchase list that came to mind when writing this statement.
table saw
router
router bits
router circle jig
clamps
palm orbital sander/paper
respirators/sanding mdf
respirators/painting
saw horses with plank
and a plethora of other goodies that pop into the basket when at home depot.(shop vac,electric blower, portable500w shop lite)
I find that abrasive dublin78.
table saw
router
router bits
router circle jig
clamps
Chubby, I think dublin was suggesting that you need not get all the tools, that rough cuts can be made by others, that's all. I don't think anyone disagrees with you that if you were to outfit yourself with all the tools for just one project, it wouldn't pay. In fact it would be a heck of a losing proposition.
Cheers.
Cheers.
Cal Weldon said:In fact it would be a heck of a losing proposition.
Cheers.
That could include a couple of fingers too!!!
Chubby: I apologise - just offering my two cents worth.
I don't see the point in putting this guy off, though. He should end up with a better end result than what would be available through retail (depending on budget, as the cheap stuff is probably hard to match). He will learn something, maybe enjoy it, and have something to be proud of afterwards. I thought that this was the point of the hobby, and the ethos of this forum?
You are correct that he will also need a set of clamps, though these are cheap nowadays too. I will stand by my previous statement, unless he uses MDF, then he will need a face fask. I prefer plywood anyway.
It depends on your price point. Towards the upper end you're looking at $25K+ a pair for stereo speakers from a high-end audio boutique, $10K+ per pair used off Audiogon, $5-6K+/pair internet direct, or $2-$3K in materials.
For example, Beethoven Elites from Audio Artistry ran $37,500 in 1998 (bettered in all areas but maximum output by Linkwitz's newer Orion design); Wood Artistry sold assembled Linkwitz Orions for $5000+ a pair; and I spent under $2000 building my own from the plans + boards package.
I haven't spent $1500 on table saw (Bosch), cordless drill-driver (DeWalt), circular saw (Porter-Cable), router (Porter-Cable), sander (DeWalt) spiral bit, and clamps. With more time on your hands you could limit yourself to just a router with flush trim and spiral bits, getting everything roughed out at the big box store.
At the bottom end, you can't compete with cut-and-fold enclosures sliced up on a CNC router, glued together in China with labor under $1/hour, populated with drivers spec'd to optimize cross-over parts cost bought in big lots, and shipped over a 40' container at a time.
This completely disregards the value of your time, although that's not relevant when you also want a fun project to do.
Trying to design a single full-range speaker would be a mistake, but there are plenty of proven designs to suit pretty much every design philosophy, placement, and budget.
PuckMercury said:I'm new here - go easy ...
I just finished building my first pair of speakers, and I had a lot of fun doing it. I think Chubby is correct to point out that if you don't have any of the tools, it can cost you. I probably spent $375 on tools to help me finish a $450 project. But, like you, I have larger ambitions and will most likely be building more speakers.
As a very green newbie, I'm slightly appalled that nobody has directed you to the best forum for DIY home theatre speakers: HTGuide. In particular, check out the "Missions Accomplished" forum. Start with this possible project's post here. It sounds like you are craving something very manly for home theatre. If you have the space, and the budget (both in time and $), consider the Statements, which have an associated center channel and very beefy surrounds coming soon. It'll cost you $1000 (at least) for left & right, maybe $350 for the center, and I don't know pricing for the surrounds ("monitors") since the design isn't finalized last I checked.
Also look at the Khanspires, or the smaller Statements. There are a bunch of designs on that site that use the metal coned Dayton drivers, and some of the same tweeters, so while they aren't all interchangeable, you can definitely use some of the designs together in a surround setup and have fairly well matched voicing. For example, I think the Modula MT is supposed to integrate pretty well with some of the other fronts & center designs.
And I wouldn't be being fair if I didn't mention there are other very skilled designers turning out L&R designs that can also have a center channel made for them. For example, Zaph's ZDT3 (being revised, but due back up shortly) is a 2.5 way tower that can have a center channel built from it. The reason I push HTGuide is because their designers really care about HT and are trying to develop full suites of speakers for HT. Zaph's ZDT3 center, for example, is probably something he'll never quite fully document, and leave for other people to figure out the details on.
If you haven't built speakers before, and don't have a lot of carpentry experience, I strongly recommend building a simple pair of two-way speakers for the experience. If you don't have speaker building experience, I also suggest you start with a WELL DOCUMENTED plan. The Statements in particular, for example, are very well documented - they even include a cut sheet. Zaph's designs are well documented, and there are others as well. Look for a clear layout, a particular BOM for Madisound and/or Parts Express, and hopefully a build thread or two for pictures that tell you what the rest does not.
Finally, as cool as HTGuide is, I find a lot of the designs there are only documented half-assed, or, in a few cases, so bloody complicated and involved I despaired of ever finding a clean set of instructions.
Oh, and finally, if you want to know about the very last (and craziest) word in DIY subwoofers, at least consider an IB Subwoofer long enough to understand what it is, and why it is so cool:
Cult of the Infinitely Baffled
This is something you CANNOT buy, but which will absolutely outperform any box sub you CAN buy, at any price. Or so I've been led to believe. This, to me, is part of the enormous appeal of DIY - something you can't have unless you do it yourself. (And cut a hole in your ceiling. Ahem.)
I hope that helps. Feel free to shoot me an email, but you'll also find the HTGuide guys very helpful I'd think.
- DIY Surround?
