diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Amplifier to Drive small speakers (http://www.diyaudio.com/forums/multi-way/122132-amplifier-drive-small-speakers.html)
haseeb 28th April 2008 02:11 PM
Guys,
I have a query ,hope this may help people who plan to drive tiny speakers with power amplifier.
I want to drive 4" speakers with impedence 4ohm and 20wattage rating by an power amplifer of 200w rms into 4ohm.
How many tiny speakers(above mention ratings) should I connect in series/parallel to attain an optimum results from the amplifier?.
My assumption if we connect 2 set of speakers( connected in series) connected in parallel ,the complete set i.e 4 speakes rating becomes 80watts into 4 ohms.
Please correct me if this is wrong.
Haseeb
sreten 28th April 2008 06:17 PM
Your assumption is correct but I am not sure how meaningful it is.
9 drivers can be wired to be 4ohms giving you apparently 180W power handling.
:)/sreten.
Cal Weldon 28th April 2008 09:26 PM
Hi Haseeb,
Perhaps you can tell us a little more and we can be more helpful.
Why a 200 wpc amp? Do you own it already?
Why 4" speakers, do you have those already?
If you don't already own both, then maybe we can get you going in the right direction.
haseeb 29th April 2008 12:35 PM
Hi Cal Weldon,
Thanks for posting the reply.
Infact I do not own both.
But, I am working on a 240watts power amp into 4ohm project.
The main design of the amp is to drive the speech at the best possible.
since the tiny speakers are good for mids and highs(I suppose) I want to drive tiny speakers with my amp.
Yes, I accept huge speakers are readily available to my maching watt ratings ,but they are prone to lows.
suggestions welcomed
sreten 29th April 2008 03:29 PM
Then I'd say a line array will be your best option, 9 or 16 drivers.
:)/sreten.
haseeb 29th April 2008 05:27 PM
How to design a line array ?.
Can I do it with same 4" speakers ,do I need to use passive crossovers to dirve the tiny speakers ?.
Infact I am new to this line array terminology.
sreten 29th April 2008 06:07 PM
http://stevebunting.com/downloads/linearrays.pdf
Column speakers have been around for years, a vertical stack of
identical drivers. Generally used in reverberant enviroments, e.g.
a railway station to improve vocal clarity of announcements etc.
http://www.pispeakers.com/ssdm_99.pdf should help somewhat.
:)/sreten.
haseeb 30th April 2008 05:24 PM
Thanks guys......!
Thats really a good stuff.
Copyright 1999-2017 diyAudio
