Help!
I am working on a 2-way which consists of Eton 800/37 woofer and Morel MDT30-S tweeter.
I actually got the design from Madisound.
I'm finding the tweeter quite dirty in the mids.
I would appreciate any help.
High Pass = 2nd Order
C1 = 8 Mfd
L1 = .4mh
L Pad
R1 = 5 ohm
R2 = 10 ohm
Low Pass = 3rd. Order
L2 = 1.8mh
L3 = .5 mh
C2 = 15 Mfd
Woofer EQ.
15 Mfd
8 ohm
If Madisound designed it, did they supply you with a LEAP FR and impedance simulation as well? I'm not familiar with these drivers but that might help identify the shape of the response and crossover point.
When you say "dirty" do you mean voices or certain instruments are recessed or lack clarity? Is this more prominent at higher volumes? Does it get better if you move off-axis? (either vertically or horizontally)? Are you playing them in a highly reflective (or highly absorbing) room?
David.
