I understand the rule of thumb is to locate a port at least one port diameter from all cabinet walls (side and back). What are the correction factors when you have to get closer than that?
Came across this useful diagram, but couldn't quite follow how the coefficients apply to enclosure tuning calculations. If someone could explain it a little more clearly, I'd be much obliged: http://www.diyaudio.com/forums/showt...24#post1148924 Also, how do I correct the calculations when I have to run a port closer than one diameter to the back wall of the cabinet? |
#2 |
Did it Himself
It's not so much you have to apply a correction factor, it's that the port becomes strangled thus not acting fully as it should.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
I'm assuming (perhaps incorrectly) that I don't ever want to get any closer to the back wall than one-quarter the port diameter--that would definitely be strangled. Even then, I'd have to leave a zone well-clear of damping material, round all edges, etc.
But in between one diameter and one-quarter diameter, what are the effects on box tuning and performance (theoretical, empirical, or anecdotal)? Likewise for a port that runs really close to the side wall (or corner) of a box. |
#4 | |
Apart from this effect, there will be increased turbulence at the inner end if the opening is too close to the back wall. 1/4 of the diameter seems too close, intuitively, but I have no hard data to support this. |
| Open baffle VERY close to back wall? | Fast1one | Multi-Way | 6 | 4th April 2009 07:01 PM |
| Measuring a loudspeaker close to a wall | wigginjs | Multi-Way | 2 | 3rd April 2009 02:02 AM |
| Good idea to close the port on a vented 8-inch 2-way ? | brjoon1021 | Multi-Way | 6 | 10th December 2007 09:46 PM |
| Effect of enclosure volume deviation on vent tuning? | rxwilson | Multi-Way | 2 | 7th January 2007 10:18 AM |
| Port Tuning | bjackson | Multi-Way | 14 | 18th April 2005 11:22 PM |
| Page generated in 0.08438 seconds (66.44% PHP - 33.56% MySQL) with 10 queries |
