Old 25th April 2008, 01:59 PM   #1
56oval is offline 56oval  Australia
Default Steel plate speaker cabinets would they work
I'm need to build cabinets for a project I have .
Been reading different threads on this forum about MDF & Ply .
Also looked at 13mm ply carbon fibre another layer of 13mm ply then a final 3 layers of carbon fibre .I have heard a cabinet constructed this way with the same drivers I'm using .
I do a bit of work with steel and looking at my mate engineering shop I'm beginning to see drivers in RHS & Large tube steel .
Could this work .
Bass driver needs to be in a 60litre cab ,mids in a sealed 12 litre
and the tweeter sitting on top no cabinet .
Or should I just build it and suck it and see .
Cheers
Old 25th April 2008, 02:08 PM   #2
gtforme00's Avatar
Would they work? Yes.
Would they be an improvement over traditional materials like MDF and plywood? No.
The functionality required of a speaker cabinet is easily met by much more user friendly materials like wood products.
I'm not saying they wouldn't be bada$$, and if you have the means don't let a little thing like practicality keep you from your vision.
Whether it is worth it or not is entirely decided by you.
Old 25th April 2008, 11:39 PM   #3
badman is offline badman  United States
Custom Title
badman's Avatar
Default strength/thickness
If you were inclined to do a steel frontplate, one potential advantage is that a very thin panel could be incredibly strong, so you wouldn't have to worry about chamfering driver mounting holes to allow free airflow.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 26th April 2008, 12:20 AM   #4
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
A combination of Steel and Aluminum with something sticky and gooey in between the layers is excellent for speaker cabinets.
If you want to just use Steel, then lining the inside with "roof repair" tape will help deaden the walls.
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
1875 heatsinking (bolt to steel plate?) wicked1 Chip Amps 2 16th July 2009 09:30 PM
Speaker Cabinets dscrobe Multi-Way 10 29th October 2007 12:54 PM
WTB speaker cabinets DonoMan Swap Meet 10 19th February 2007 03:34 AM
Custom Stainless steel speaker terminal plates amit uk Swap Meet 0 17th January 2007 03:45 PM
Steel cabinets? bfg9k Multi-Way 1 5th January 2004 03:35 AM
Page generated in 0.07266 seconds (70.09% PHP - 29.91% MySQL) with 10 queries
