Help, I've got a tear in one the drivers its listed in my documents as a 8"long excursion wooofer, its an American speaker can I get a replacement driver here in the UK
#2 |
Should be easy to repair, for paper cones use PVA wood glue.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 |
many thanks for the advice, can the glue just be applied to one side only or does it need to be applied to both sides
#4 |
Custom Title
Use the glue in combination with some small sections of tissue paper, on both sides. Don't build it up too much, try to keep the repair profile very low.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#5 |
A picture of the tear would help. Generally apply along the edges of the tear - from the back if that is possible for neatness. Even from the front usually not too noticable. Tissue paper is only needed when there are gaps to bridge.
#6 |
I get the picture, do you thing that the rubber sourounds should be changed at this time?
| Repair Allison 105 Help | skinumb | Multi-Way | 6 | 20th June 2011 12:37 PM |
| Simulation Analysis of several unique Allison-based output stages. | keantoken | Solid State | 616 | 12th March 2011 12:22 AM |
| Roy Allison bass method | zigzagflux | Subwoofers | 7 | 7th April 2009 01:21 PM |
| Page generated in 0.08940 seconds (76.56% PHP - 23.44% MySQL) with 10 queries |
