Old 24th April 2008, 01:24 PM   #1
rickp15 is offline rickp15  United States
Default Line array's for HT use
I would like to build 3 sets of line arrays, one set at a time of course. I have read Mr Griffins white paper a few times before it was removed. For the first set rather than design anything new I would like to use some plans for a proven design. I am in process of building a IB subwoofer that won't be run over 50Hz because the vent goes to the exterior of the house. The line arrays will use an active crossover. multy amps per set of LA's not a problem.
The room is 12.5' x 13' the ceiling is 8.5' the room has 2 -10" risers for seating. Double insulated walls and ceiling with a 3" air gap, there is also 2 sealed doors.
I could use some help with:
design
woofers/mid woofers?
tweeters
All advice is greatly appreciated
Regards, Rick.
Bass is Good
Old 24th April 2008, 01:26 PM   #2
Goals Post #3
Rick,
What are your objectives here? Why are you leaning towards multi-way line source speakers for your HT as opposed to point sources -- iow, what are you trying to achieve and what compromises are you willing to live with? Budget? Are you planning to have all 6 working into the same room? Lastly, will you have active eq options?
BTW, IB subs are excellent in my experience.
Bass is Good
Old 24th April 2008, 01:28 PM   #3
Post #4
To have an extreme theater experiance.
I like the ability of the line array to disperse sound so that all the 10-12 seats will have very good sound not just the one in the sweet spot seat.
quote:
iow
Please forgive my ignorance, what does iow mean?
Maximum sound experiance, at this point I don't even know what the compromises are.
Yes , I don't know what I will do for a center channel yet, I have read LA's dont work horizontally.
Eq is wide open at this point.
Actually everthing is wide open at this time except the placement of the IB and the room size. And that is why I am asking for help before I make a lot of costly mistakes. I hate paying stupid tax.
Budget, I can spend about 1500$ per set of speakers
Thanks in advance, Rick.
Bass is Good
Old 24th April 2008, 07:48 PM   #4
sdclc126's Avatar
http://www.zalytron.com/
Several line array kits.
Soft Dome
Old 24th April 2008, 09:45 PM   #5
These two places both sell several kits.
(1) GR Research line arrays are amazing, but take a fair amount of power to drive.
(2) Selah Audio line arrays are also amazing, and most are very efficient.
I've heard the former and own the latter. Work extremely well as the fronts in a home theater.
This forum is dedicated to line arrays and has quite a few experienced members:
http://audioroundtable.com/ArraySpeakers/
JVC line array nebojsa Multi-Way 26 3rd July 2009 04:34 PM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
t-line subs for a DIY line array tom1356 Multi-Way 17 28th December 2002 12:15 AM
Page generated in 0.09528 seconds (77.49% PHP - 22.51% MySQL) with 10 queries
