Old 24th April 2008, 05:04 AM   #1
CLS is offline CLS  Taiwan
Question Relationship among T/S Parameters
I mean, I got some very basic understandings about those T/S parameters. But how do they affect one another?
For my project which is now on planning, someone suggested this 15" Monacor woofer to me:
http://www.monacor.de/typo3/index.ph...ukatid=&brand=
Here I digested some of its T/S parameters:
Resonant frequency (fs) 23Hz
SPL (1W/1m) 96dB
Suspension compl. (Cms) 0.3mm/N
Moving mass (Mms) 160g
Mech. resistance (Rms) 3.1kg/s
Mech. Q factor (Qms) 6.36
Electr. Q factor (Qes) 0.29
Total Q factor (Qts) 0.26
Equivalent volume (Vas) 284 l
DC resistance (Re) 2 x 6£[/ 3£[
Linear excursion (XMAX) ¡Ó7mm
Eff. cone area (Sd) 850cm2
Volume displacement (Vd) 595cm3
Force factor (BxL) 16.72Tm
TBH, I suspect some of the numbers above.
According to my basic understanding, the fs is determined by the moving mass and the suspension compliance. Now its 160g of Mms for a 15"er seems quite heavy, so 23Hz is possible.
Moving on to the SPL, it should be tightly related to the ratio of BL and Mms. Its BL is a moderate 16.7TM, but it's pushing a relatively heavy cone of 160g. Is it possible to produce 96dB/w/m?
Or it's measured at 2.83V into its paralleled duo voice coil? Thus a +3dB gain (by cheating)?
In addition, the 0.26 of Qes dominates total Q (Qts), which is quite low, means this motor is quite strong for the cone. But how do BL / Qes / Mms affect one another? Is there any mathematical relations?
I don't remember any other driver comes with such combinations: moderate BL (16.7), heavy cone (160g), Low Q (0.26), Low fs (23Hz), pretty high SPL (96db/w)...
Any thoughts?
Old 24th April 2008, 09:44 AM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi, There is nothing wrong with those parameters.
If you cross calculate you will only find that rounded off values must been used when advertising this driver.
The first thing to do with this type of extensive data is always to figure out how the TS data is collected, i.e. how the driver is hooked up, parallel, series or single coil, before you check the consistency. In this case it’s with the coils in parallel.
b
1(1)
Old 24th April 2008, 09:59 AM   #3
AndrewT is online now AndrewT  Scotland
I'm inclined to agree that most of the parameters look OK if we assume the VCs are wired in parallel for the sensitivity test and should read~96db/2.8V/m and not 96db/W/m.
regards Andrew T.
Old 24th April 2008, 10:32 AM   #4
MaVo is offline MaVo  Germany
There are some formulas: http://en.wikipedia.org/wiki/Thiele_small
Old 25th April 2008, 01:03 AM   #5
Thanks a lot Now I have a clearer picture.
Old 25th April 2008, 01:54 AM   #6
A key parameter that affects SPL is Vas -- the equivalent spring in air volume that the motor is pushing. 284 liters equals 10 cubic feet -- a rather small spring. So these numbers don't seem immediately suspicious to me. Look at some car subwoofer Vas figures -- when you see a 15" sub with a 2 cu foot Vas and 96 db SPL -- be suspicious!
JJ
The relationship between air volume and SPL Onur Multi-Way 13 30th October 2007 01:07 PM
A Love/Hate Relationship bulgin Everything Else 18 17th December 2006 06:48 AM
Sealed vs. ported... and what their relationship to BSC is? fjhuerta Multi-Way 0 30th August 2005 04:50 PM
voltage-sonic relationship in Gainclone Russell Sit Chip Amps 4 20th May 2003 08:33 AM
Relationship between Fcb, F(3) and Qtc in a closed box sub Dave Bullet Subwoofers 11 9th January 2002 03:52 PM
Page generated in 0.08939 seconds (72.56% PHP - 27.44% MySQL) with 11 queries
