Old 23rd April 2008, 05:17 AM   #1
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Default Zaph, 36mm Forstner Bit...
36mm Carbide Forsner bit
Not cheap, but, if I was going to make more than a few pairs of speakers with the ND20 tweeter I guess I'd get one? (if the fit would be snug but not too tight to fit)
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 23rd April 2008, 07:27 PM   #2
Zaph is offline Zaph  United States
Zaph's Avatar
Congrats, that's the first 36mm I'm seen. That should be perfect. But, I'd have to be mounting about 100 of these to make that bit worthwhile. (Anyone building a line array with these tweeters, take note) But for the average guy, a cheaper 1-7/16 is better. I've got a 1-3/8" that works but is a little sanding intensive.
-Zaph|Audio-
Old 23rd April 2008, 09:35 PM   #3
If you knew someone with a lathe, it's literally a 2 minute job to just turn the major diameter of an oversized, imperial forstner bit down to spec. A viable, cheaper, and faster route of going.
Heck, depending on the type of forstner you have, you can run a file along it while it rotates at a low speed in your drill press; effectively turning it down to whatever diameter you desire. Just clean up the teeth and chip removers with some small needle files when you're done!
Old 13th March 2011, 08:29 PM   #4
critofur's Avatar
Smile Cheaper [but still carbide tip] 36mm Forstner bit
File huh? Diamond file?
Found a much cheaper source, I THINK this is a 36mm bit - I'm not certain if the 36mm is the width of the hole, but I think so?:
Southeast Tool SEHB5736RH - Hinge Drill Bit, 36mm Dia., 10mm Shank
Price seems good, anyway.
Critofur
I just built Zaph's HiVi B3s speakers... thanks a lot, Zaph! :) fjhuerta Multi-Way 21 23rd May 2011 10:46 PM
Speaker idea based on Zaph ZD5, thoughts please, Zaph? wigginjs Multi-Way 23 3rd April 2009 05:09 AM
Binding posts for 36mm thick panel? wixy Multi-Way 5 11th August 2007 07:25 AM
@Zaph martinkruit Everything Else 0 2nd May 2007 11:46 AM
Page generated in 0.09979 seconds (77.04% PHP - 22.96% MySQL) with 11 queries
