Some of you might have read about my project in the old "which loudspeaker design?" thread, where I decided to go for the line array design. This far the mid-array is finished and is up and running together with single tweeters, and the bass cabinets are under construction. Meanwhile I am having second thoughts regarding the tweeters. I was very curious about long diy magnetostatic ribbons, so much I even bought a bunch of neodymium magnets. Now I find time and build-space being a problem and start to consider an array of dome tweeters or short ribbons instead, to make it all a little easier. The Dayton ND20FB or ND20FA seem to be popular choices. Are there any other small tweeters out there worth considering or are these the only suitable? Or perhaps any ribbon tweeters reasonably priced? For info; I use a 6 channel surround amp in stereo with 3 amps per speaker, and a Behringer DCX2496 active filter, so steep filter slopes and varying driver sensitivity should not be any problem. Please comment! /Magnus |
#2 | |
http://www.apexjr.com/speakerstuff.html
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 |
Yes, I have seen those as well, but from what frequency can they be used? I have 83 mm c-c mid woofer distance and can't go too high with them because of comb filtering.
Can a lower tweeter frequency be used with wave guides? How is their sound quality? Mylar membranes? /Magnus |
#4 | |
advice needed for cheap line array tweeter Quote:
#5 | |
b |
#6 |
2(2)
#7 |
Back again, still thinking about tweeters for my arrays!
Compared to the Dayton ND20, what do you think about the Hi-Vi T20?: http://www.madisound.com/catalog/pro...oducts_id=8317 /Magnus |
#8 |
These are interesting as well! But I do realise that 4000 Hz is too high...
Tang-Band 13-1761S http://www.parts-express.com/pe/psho...41&ctab=2#Tabs |
#9 |
Hello,
I have built 3 meter line arrays using 4.5" HM100CO Audax drivers and Audax small dome tweeters. I am now upgrading to the BG NEO8 PDR (available from parts express) with an open baffle. The NEO8 PDR's sound much better than the domes IMHO. Just buy 4 or 6 and give it a try on a small open baffle. You will be supprised how great and natural they sound. Don't put them in an enclosure. I did, and they do not sound anywhere as good. I am now upgrading my HT to open baffle with 12 Silverflute W17RC38 (6.5") and 9 NEO8 PDR's per side. http://www.parts-express.com/pe/show...number=264-713 |
| A line array using HiVi B3S or B3N & Apex Jr tweeters? | Brisso57 | Multi-Way | 6 | 10th August 2007 08:02 PM |
| Mounting tweeters over the woofer in a line array. | GuyPanico | Multi-Way | 8 | 28th June 2007 11:10 PM |
| Tweeters for line array? | dublin78 | Multi-Way | 14 | 12th May 2007 03:08 AM |
| FS HUGE Line Array Cabs/W Tweeters | Turboegt | Swap Meet | 9 | 27th September 2005 02:22 PM |
| Line array tweeter line - On left or right? | dhenryp | Multi-Way | 4 | 9th March 2005 11:35 PM |
| Page generated in 0.11606 seconds (75.74% PHP - 24.26% MySQL) with 11 queries |
