Efficient two way using compression tweeter
Old 21st April 2008, 07:31 PM   #1
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Cool Efficient two way using compression tweeter
http://www.partsexpress.com/pe/showd...number=264-271
http://www.partsexpress.com/pe/showd...number=270-312
http://www.partsexpress.com/pe/showd...number=290-408
Has anyone considered using parts like these to build an efficient two way for home use? The frequency response on this new compression tweeter looks smooth. I want a bouncy, live sound that will rock the house. There are many 12 inch woofers to choose from that seem to be good choices. Or will this speaker sound rough and unlistenable? Crossover around 1200 to 1800khz. This would be about 99db per watt… Any thoughts?
Old 21st April 2008, 08:42 PM   #2
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
How about giving this one a try? http://www.decware.com/newsite/mainmenu.htm Could be a pretty cool multi purpose set up; mains, monitors etc... Dave
The link is supposed to lead to the pro-sound cab in the speaker section
Old 21st April 2008, 09:14 PM   #3
MJK is offline MJK  United States
Yes.
Old 21st April 2008, 09:51 PM   #4
LAL is offline LAL  United States
You might try one of the Pi Speaker kits. See Audio Round Table forum
Old 21st April 2008, 09:58 PM   #5
nicoch58 is offline nicoch58  Europe
HI
If use the alpha ,look likeClick the image to open in full size.
Emerald Physics CS2.....
Old 21st April 2008, 10:49 PM   #6
Godzilla's Avatar
I was thinking of putting the drivers in a box, not open baffle. But basically yes, these types of drivers for home use and high eff. Are they too rough sounding or will they do justice to hi fidelity? I don't want to bother with 'bar mitzvah' speakers.
Old 21st April 2008, 11:26 PM   #7
I believe they will work very well in home hi-fi systems. I am in the early stages of looking at them and doing something with my four Alpha 15A's on an OB or H frame and mated with other drivers one of which would be a compression driver and horn.
Old 21st April 2008, 11:54 PM   #8
ttan98 is offline ttan98  Australia
I have tried the 10" circular horn from PE and found it to be not very good.
I suggest you give the RCF H100 horn a look from Loudspeakers Plus(where you can download the spec.), costs $28 each. It suits my B&C DE250 very well the freq response is quite good no excessive bum or dips, you can get away without equalization.
H100 can be x-overed at 800Hz according to the manu. recommendation, I x-over mine around 1.7Khz.
My combo sounds quite good, I am still tweaking it.
My system is similar and not a clone of EP, CS2, Tweeter woofer, woofer(TWW) configuration. I am happy with this config., I have tried a few. It is worth a try.
cheers.
Old 22nd April 2008, 09:12 AM   #9
G is offline G  United States
G's Avatar
This woofer:
http://www.partsexpress.com/pe/showd...number=264-332
and this tweeter:
http://www.partsexpress.com/pe/showd...number=264-362
seem like they would make a nice combination.
Gavin
Old 22nd April 2008, 11:24 AM   #10
Piek is offline Piek  Europe
Piek's Avatar
I am using an RCF CD1710MT3 1" on RCF H100 crossed over at 1200Hz to 8" Celestion Truvox 0818 and at 200Hz 2x KEF B139 in closed box for bass. Of course with a 12" this would be a nice 2-way.
Look at the Menhir by Monacor/Celestion 1" + 12" should be really nice: http://www.lautsprecherforum.com/forum/index.php?id=75 kit is right now for sale, by developer: http://www.hifi-forum.de/index.php?a...188&thread=665
Cheap 10" Koax by German Klang&ton Magazine?: http://www.lautsprecherforum.com/for...e=thread&id=95
regards, Micha
Efficient two way using compression tweeterHide this!Advertise here!
tweeter ( Compression driver) protection circuit jaya000 Solid State 96 31st July 2012 12:47 AM
Compression ratio and diaphragm size in compression drivers inkasound Multi-Way 50 8th January 2009 04:38 PM
compression tweeter lizgar Multi-Way 1 19th May 2008 01:55 PM
Most Efficient Speakers ? EdT Multi-Way 6 19th August 2007 12:55 AM
Copyright ©1999-2017 diyAudio
