Old 20th April 2008, 04:32 PM   #1
godless is offline godless  United States
Send a message via AIM to godless Send a message via MSN to godless
Default Notch filter
What exactly is the "notch filter" that B&G is talking about when they refer to the specs of their RD line of transducers?
Thanks!
Old 20th April 2008, 06:13 PM   #2
Speakerholic
Cal Weldon's Avatar
Do you want to know about that particular one or just what a notch filter is?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 20th April 2008, 07:44 PM   #3
A notch filter is just the opposite of a band-pass filter. A band-pass filter would pass a certain range of frequencies (all the frequencies inside the band), while it would cut out all the others. A notch filter cuts out a certain band of frequencies (all the frequencies inside the notch) and passes everything else.
Old 20th April 2008, 08:44 PM   #4
I see, do you happen to know which frequencies BG is cutting out with the notch filter they are using in the RD40?
Old 22nd April 2008, 08:00 AM   #5
No, sorry.
Old 22nd April 2008, 09:26 AM   #6
kstrain is offline kstrain  Scotland
Default from BG data sheet
The RD series drivers should be used with a notch filter which equalizes a natural frontal cavity resonance.This peak is pronounced in the 5 kHz area on-axis, with a diminishing peak further off-axis.
Sounds undesirable.
Ken
google bg rd40 notch filter
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Notch filter qguy Multi-Way 3 26th October 2006 09:26 PM
Do I Need A Notch Filter? noodle_snacks Multi-Way 13 31st October 2005 01:35 PM
Help with notch filter nobody special Multi-Way 1 11th June 2003 02:06 PM
Page generated in 0.08303 seconds (71.03% PHP - 28.97% MySQL) with 10 queries
