Old 19th April 2008, 12:06 PM   #1
Default Modulus 3way
Hi Im interested in building these speakers ; http://www.humblehomemadehifi.com/Modulus.html
Has anyone non here built them or heard them? I will be using 80w valve mono blocks and my room is about 5m by 3.5m., i will probably have to adjust the bass cabinate size as i would like them around 2 ft from the front wall....thanx...James
Old 19th April 2008, 02:45 PM   #2
Default Re: Modulus 3way
I asked Tony to design this speaker for my personal set-up using some of my ideas/wishes.
Some thoughts:
Efficiency isn't on the high side (88dbs) mainly because of the sealed bass enclosure; 80watts are OK but remember the mid-bass has no high-pass thus not a party speaker. 2 feet from rear wall should be OK, Tony voiced the speaker approx in this same way.
Adjusting the bass cabinet sizes in what a way? Vb?
Sound is caracterized by a low level of colourations for a system using paper drivers mainly because of the chosed types of loadings, a nice "oneness" (Tony's //-series filter fingerprint), good dynamics all around the fr range, an "airy" trebles with some "sparkles" effects (ruban tweeter) and a remarkable "openess" of the imaging.
Listening impressions on Tony's website Modulus page are mine.
crazyhub
Old 19th April 2008, 03:42 PM   #3
Unhappy Thanks
Thanks for your reply,i emailed tony and he said the speaker will work in my room without mods to the bass cabinate.It an interesting design.I realy like an open image like electrostatics have but i like a nice tight bass too so these should deliver.Crossovers are going to be rather expensive to buy though.
Old 19th April 2008, 04:36 PM   #4
Default Re: Thanks
L1 can be foil16AWG or round 1 or 1.4mm, L2 can be 14AWG or 1.4mm because the middriver and tweeter are sufficently efficient so you can tune by modifying the resistors if needed. And the most expensive cap C1 can be of another brand/price than Mundorf silver/oil, I think on Jantzen Superior Zcap for exemple or a mix of both.
My two cents
crazyhub
Old 20th April 2008, 01:27 AM   #5
blue934 is offline blue934  Canada
crazyhub, how tall are these speakers? i can't read the low res pic on tony's site.
blue934
Old 20th April 2008, 04:49 AM   #6
Mine are (overall) w30.5cm h101cm d55cm
bass cabinet:
mdf 22mm
+10mm on sides
front and rear baffles doubled=44mm thick
OB:
mdf25mm
horizontal wall 25+19mm thick
crazyhub
Corian young modulus ? inertial Multi-Way 33 1st May 2009 03:42 AM
infinity modulus subwoofer wanted The Rug Doctor Swap Meet 1 28th August 2007 06:43 PM
Audible Illusions Modulus faulty? st2_998 Tubes / Valves 4 25th August 2007 02:20 PM
Audible Illusion Modulus 3 preamp Pdspecl Analog Line Level 0 11th February 2007 01:12 PM
May Have Fried My Infinity Modulus Subwoofer Agent_C Subwoofers 1 2nd February 2005 09:35 PM
Page generated in 0.10104 seconds (72.65% PHP - 27.35% MySQL) with 10 queries
