Mounting speakers by their magnets? Mounting speakers by their magnets? - diyAudio
Old 18th April 2008, 11:30 PM   #1
santiu is offline santiu  United States
Default Mounting speakers by their magnets?
What are the benefits of this as opposed to regular mounting? I'm thinking of doing this on my next OB project to reduce baffle vibrations.
When people do this, do they normally just glue the magnet to a structure? Any preferred glues? I'm afraid something like a hard epoxy will be too brittle and possibly crack over time from the vibration.
Is it better to have a hole cutout that is the size of the speaker so that you are only sealing against the circumference of the frame, or have a cutout that is only slightly bigger than the cone surround and have the frame face pressed up against the baffle?
thanks for any comments/advice!
Old 18th April 2008, 11:39 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
The idea is to mechanically decouple the driver from the baffle. You want a soft gasket mounting with minimal force, just enough to seal it airtight. I think most people do glue to the magnet, but some have drilled or used other mounts.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 19th April 2008, 12:12 AM   #3
Peter Menting is offline Peter Menting  United States
On the Audio Circle site in the "open baffle" section there are some different approaches used, including circular wood clamps. Lots of pictures as well. Linkwitz' "Orion" has a retrofit kit for that purpose as well. Hope this helps--!
Pete
Mounting speakers by their magnets?Hide this!Advertise here!
Flush mounting speakers: the whole story loninappleton Everything Else 31 16th January 2013 03:06 AM
Mounting speakers behind a wall brox Full Range 0 13th November 2007 08:53 PM
In-wall (soffit) mounting for ESL speakers? Consul Planars & Exotics 5 19th December 2006 06:52 PM
mounting speakers near wall/ceiling juncture ultrachrome Multi-Way 6 27th January 2004 04:13 AM
Copyright ©1999-2017 diyAudio
