New Project Build Thread New Project Build Thread - diyAudio
Old 18th April 2008, 10:37 PM   #1
ryoung is offline ryoung  United States
Default New Project Build Thread
After building my first 2 way bookshelf, I was looking for something a bit more "hi-fi" and have been working on this design for a while. At this point my drivers of choice are the Scan-Speak D3004/6600 for the tweeter and the Revelator 22W/4851T. I'm still working on the crossover, but any suggestions would be great.
Old 18th April 2008, 10:41 PM   #2
heres an exploded view
Old 19th April 2008, 12:34 AM   #3
Jay_WJ is offline Jay_WJ  United States
Considering this 8" driver's beaming, I'd cross it at 1.5 to 1.6 kHz LR4. 2 kHz LR4 will be the highest possible. If you want to try LR2 with a delay network, you need to consider 7" or smaller driver.
If you want to cross low, the 7100 is a better choice than the 6600. The Peerless 810921 or the Dayton RS28A-4 is a low cost alternative for low crossover freq.
What's the cabinet volume? You will need at least 1 cu ft for this 8".
Old 19th April 2008, 12:47 AM   #4
Cabinet volume is 1.25cu ft, port is 3"x8". My initial thoughts on the crossover was a 1500kHz crossover point for the drivers...I'd looked at the 7100 and havent been able to decide between that one and the 6600. Maybe i'll buy both and try them out!
Old 19th April 2008, 12:53 AM   #5
According to Zaph's measurements, the 7100 has lower distortions below 1.5 kHz than the 6600.
http://www.zaphaudio.com/tweetermishmash/compare.html
Old 19th April 2008, 01:15 AM   #6
7100 it is then.
New Project Build ThreadHide this!Advertise here!
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
aikido build thread- nate Tubes / Valves 1 27th February 2009 05:01 AM
My SE KT-88 Build thread athos56 Tubes / Valves 13 21st December 2008 06:16 AM
PDX Zaph SR-71 Build Thread StewLG Multi-Way 194 4th May 2008 01:11 PM
The ESL Build Thread BillH Planars & Exotics 172 8th November 2006 09:01 PM
Copyright 1999-2017 diyAudio
