Old 18th April 2008, 02:59 AM   #1
Default da175 and hivi b1s dipole speaker
here is another weird project from mistertwister.
da175's cones are slit and covered with cascade damping spray.
so they've become dayton revelators
hivi tweeter will be horn/waveguide loaded.
this is a leftovers project, I'm not buying any more parts for it.
just using whatever junk I can find in my house.
Old 18th April 2008, 06:30 PM   #2
sdclc126's Avatar
How did you "slit" aluminum cones? Or did you slice the damping spray after application?
Have you measured the woofers to see what affect the spray has?
What sort of XO are you planning?
Soft Dome
Old 18th April 2008, 07:07 PM   #3
badman is offline badman  United States
Custom Title
badman's Avatar
Yeah, same re: slicing.
did you do before/after measurements?
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 18th April 2008, 08:04 PM   #4
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
As with the above comments, if you have no means of measuring the T/S parameters and frequency response (distortion plots would also be a big plus) I would have to say that you've effectively rendered your drivers useless. I have to assume you have some means of measuring frequency response since you plan to put the HiVi 1" drivers in a waveguide.
Visually, the copper center plug looks nice, but the cone coating looks lumpy and gross. Hope it's not sticky, or it might be a furry driver in a year or so.
The power of Science compels you!
Old 19th April 2008, 03:23 AM   #5
aluminum cones are slit with utility knife.
I'll do some measurements after I mount drivers on baffle.
and I already did freeair distortion measurements, just to
check that there is no serious problems with drivers.
cones coating is not sticky, it's damping material for cars.
i've done one pair of speakers with hivi tweeters already,
Hi-vi B1s
those speakers were pretty much lucky accident
I hope these will be too
Old 23rd April 2008, 02:14 AM   #6
da175 distortion.
both drivers mounted on baffle, measured at 14in on tweeter axis.
I think it's good enough, there is no offensive peaks.
unfortunately my winmls pro demo expired. I think it gives more accurate harmonic distortion results than arta.
Old 23rd April 2008, 02:22 AM   #7
b1s without rear chamber, same 14in distance.
Old 29th April 2008, 03:43 AM   #8
I made series crossover -> 0.2mh inductor and 30mfd cap
there are two ugly dips in frequency responce.
my only hope is that longer phaseplugs will fix those dips.
I didn't listen to these speakers in stereo yet, so can't comment on how they sound.
Old 8th May 2008, 03:13 AM   #9
measured at 18in on top woofer axis (it's more like listening axis if one sits on a couch) 2k area distortion is always there on both speakers.
Old 8th May 2008, 09:12 PM   #10
Did you just mask them and spray? That's awesome. Bozak used to perforate their aluminum midrange cones and rubber coat both sides. Always seemed like a great idea to me.
Questions regarding HiVi M4N and messing with speaker box sizes blackspur Full Range 1 5th September 2008 03:32 AM
3" HiVi speaker project Thanks Zaph! hybridfiat Multi-Way 4 30th July 2008 04:31 AM
HiVi vs Peerless new speaker design guru_jeff Multi-Way 2 18th July 2006 03:14 AM
HiVi vs Peerless new speaker design guru_jeff Multi-Way 0 17th July 2006 07:28 AM
Powered Zaphaudio style HiVi B3N speaker using a Chipamp w/ active filters DaMeat Full Range 1 14th April 2006 05:34 AM
Page generated in 0.13030 seconds (69.96% PHP - 30.04% MySQL) with 11 queries
