Safely using large router bits?
Old 18th April 2008, 01:00 AM   #1
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Default Safely using large router bits?
I bought a couple of larger round over types including a 1-1/2" and 1" type. Now that I have these in my hand they seem too large to use safely in a regular router - I even have my doubts in the router table with the 1-1/2", its quite large:
I can't remember seeing any projects using roundovers of this size so I'm guessing its not a great idea. I haven't tested or tried any yet because I'm too chicken now that its dawned on me how large they are!
Any thoughts or experience you could share before I rip my arm off?
The more you know who you are and what you want, the less things will ever be the same.
Old 18th April 2008, 01:15 AM   #2
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Hi Ant,
I have used these large bits (round overs and even panel raising bits) in the hand held router. You need to solidly clamp the work piece down and have a firm grip on the machine.
It is also a really good idea to make several passes to get to the final finished cut. Lowering the bit by 1/4" increments will get it done safely and smoothly.
Good luck!
Old 18th April 2008, 01:41 AM   #3
Phil Olson is offline Phil Olson  United States
I concur. Take several passes, lowering the bit each time. It doesn't take that much more time anyway.
Old 18th April 2008, 01:56 AM   #4
tjmac44 is offline tjmac44  United States
1. Router Table.
2. Variable speed router, 10000 - 12000 RPM, with soft start.
3. Several passes.
I would not attempt to use large bits free hand.
Old 18th April 2008, 02:03 AM   #5
Conrad Hoffman is offline Conrad Hoffman  United States
I've always been under the impression those large bits are for a fixed floor standing router, not a hand unit or a hand unit mounted in a portable router table. Email the manufacturer- no doubt they can better advise you.
I may be barking up the wrong tree, but at least I'm barking!
Old 18th April 2008, 02:13 AM   #6
lepomis is offline lepomis  United States
I would also add to this that you should be using feather boards as well. One to control lateral movement and one to control vertical movement of the stock.
Originally posted by tjmac44
1. Router Table.
3. Several passes.
Old 18th April 2008, 02:14 AM   #7
ShinOBIWAN's Avatar
Thanks guys, pretty much what I was thinking but guess I needed to hear it from a couple of other people to make sure it was safe.
I just tried fitting the larger 1-1/2" bit into the router and realised that it fouls the baseplate unless you increase the depth of the plunge in order to clear the obstruction. I think this little problem makes the 1-1/2" bit a router table only job. The 1" fits fine though.
Are there any routers out there with larger openings in their base plates for these types of bits?
Old 18th April 2008, 02:15 AM   #8
ShinOBIWAN's Avatar
I'm not familiar with this. Could you explain?
Old 18th April 2008, 02:16 AM   #9
MJL21193's Avatar
Difficult to do with a fully constructed speaker box...
Old 18th April 2008, 02:23 AM   #10
Oh, I misunderstood. You would not need the feather boards with a heavy box.
This is a picture of feathers boards used with a table saw.
featherboards
Safely using large router bits?Hide this!Advertise here!
need to discharge psu safely Aidan135711 Tubes / Valves 6 8th March 2008 10:03 PM
how much capacitance can i add safely? Clipped Car Audio 8 28th September 2007 10:40 PM
router bits for flush mounting eisenhower Multi-Way 12 27th December 2006 01:24 PM
Heads UP. Super deal on router bits! rcavictim Equipment & Tools 7 26th September 2006 03:17 PM
VRDS-10. how do I get to the laser to clean it safely??? flipflip Digital Source 8 3rd August 2004 05:36 PM
