diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Xover Coil R/Ohm Question (http://www.diyaudio.com/forums/multi-way/121518-xover-coil-r-ohm-question.html)
trummis 17th April 2008 08:12 PM
I am about to upgrade my Xover for my Scanspeak 9700 and 8545.
The current coil for the tweeter has Rdc=0.32. I want to go all the way, Mundorf CFC 12, with a Rdc=0,07.
Now, am I barking up the wrong tree here? Is this a major concern or a minor problem? If its a problem, please enlighten me!
Thank you very much
Roger
vdi_nenna 17th April 2008 08:48 PM
Looks like the Mundorf has less resistance. Maybe by design it offers less DC resistance, which is good.
Are you checking the inductor value also, that is, the Henries? For example, 1.3 mH or .5 mH or other value from the original coil.
Determining the old coil value may require a meter, if it is not marked.
Vince
Svante 17th April 2008 09:36 PM
I would advice to get a coil with the same resistance and inductance as the original coil. Using a lower resistance might actually spoil the response of the speaker.
Then again, I would advice not to change it at all, if it has the same L and R, nothing will change.
... or if I suspected that there is potential for improvement in a given design, I would do some measurements to confirm that, before I did the change. I would not just change components blindly to something "better".
Dave Bullet 17th April 2008 09:51 PM
You are talking about 0.25 of an ohm. Depending on how the coil is used for the tweeter (parallel notch, impedance compensation etc...) maybe 0.5 ohm or more might affect the response, but I doubt you could audibly tell the difference of 0.2ohms.
You also need to look at tolerance of components esp. around inductance values. your current inductor might be +/- 5% or more so keeping within the tolerance inductance is safe.
David.
bjorno 18th April 2008 01:04 AM
2 Attachment(s)
I would advice to get a coil with the same resistance and inductance as the original coil. Using a lower resistance might actually spoil the response of the speaker...
Agree.
...You also need to look at tolerance of components esp. around inductance values. your current inductor might be +/- 5% or more so keeping within the tolerance inductance is safe...
Agree again.
See an example: 1(1)
b
1(1)
sreten 18th April 2008 12:28 PM
Re: Xover Coil R/Ohm Question
Roger
The short answer is yes you are.
It is fairly pointless "upgrading" a tweeter inductor if there is nothing
wrong with the original. Lower DCR will likely do nothing useful.
:)/sreten.
Inductor 18th April 2008 02:35 PM
Please post the xover for that driver (before/after). If you can, post the xover complete with drivers you use for a better understanding of what is at stake here.
Copyright 1999-2017 diyAudio
