Old 17th April 2008, 04:47 PM   #1
Default 4ohm and 8ohm LR4 xo
Hey all, i've designed and plan to build a vented floorstander using the 8ohm peerless 6.5" nomex woofer and the 4ohm XT25 vifa ring radiating tweeter. I've calculated a proper LR4 crossover, but i am not sure if there is anything else i need to add to the crossover to compensate for the ohm difference between the drivers. I know that the calculations i used to calculate the crossover took the resistance of each driver into consideration, but i am not sure if there is anything else i need to add to XO to make sure that everything works out well, if anyone has any experience crossing over these drivers or some advice as to what i should do to build an ideal crossover for these drivers considering their ohm difference, any advice/input is greatly appreciated, than you very much, cheers, Luke
Old 17th April 2008, 05:09 PM   #2
Theoretically you can zobel and impedance compensate the drivers
but your "calculated" LR4 crossover will still be completely wrong.
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://www.geocities.com/woove99/Spkrbldg/
http://www.zaphaudio.com/ see http://www.zaphaudio.com/audio-speaker19.html
For an example of an acoustic LR4 crossover (2nd order electrical).
/sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
8ohm speakers 4ohm tap 5u4 Tubes / Valves 1 17th April 2009 11:22 PM
4ohm speakers for 8ohm application? SikSS Full Range 4 15th December 2007 04:09 PM
8ohm or 4ohm? adrrad Chip Amps 5 21st October 2007 04:29 PM
4ohm Sub driver to 8ohm Sub amp? WBFAir Multi-Way 10 31st March 2007 01:29 AM
4ohm Car Speaker to 8ohm Use? jdgonko Car Audio 1 20th April 2006 02:40 AM
Page generated in 0.06595 seconds (71.11% PHP - 28.89% MySQL) with 10 queries
