logitech x-140
logitech x-140
Old 16th April 2008, 08:24 PM   #1
raindog is offline raindog  Romania
raindog's Avatar
Send a message via Yahoo to raindog
Default logitech x-140
Just took apart the Logitech X-140 PC speakers http://www.logitech.com/index.cfm/sp...214&cl=roeu,en ( they where a present from a friend ) and I found a few (un)pleasant surprises inside: the ,,inovative two-driver design" was actualy a single driver with a passive one added for a little more bass ( as you can see from the pictures ). Another ,,fun" discovery was the unshielded input cable and the fact that the output wires of the transformer ( witch is housed in the left speaker and the amp pcb - includind the rectifier bridge and filter capacitor - is in the right speaker ) is in the same ,,coating" with the output wires for the left speaker. The amp board is pretty simple - a ST TEA2025B amp, two transistors for the tone control and a few parts for the ,,Real-time bass equalisation" ( whitch I suspect is just a simple loudness circuit ). I wonder if someone recognises the driver ( the only inscription is 170091-0000 and 137361 ). Any sugestions on emproving these speakers are welcome
Old 16th April 2008, 08:26 PM   #2
raindog's Avatar
Default front view
from the front
Old 17th April 2008, 02:21 AM   #3
R-Carpenter is offline R-Carpenter  United States
R-Carpenter's Avatar
iaiks!
http://www.diy-ny.com/
Old 17th April 2008, 01:41 PM   #4
technofreak is offline technofreak  Estonia
technofreak's Avatar
Send a message via MSN to technofreak
It's a known fact that Logitech is very keen on passive radiators - they use them in their Z-4 (IMO one of their worst designs) in sub AND satellites! I think that PR in a dedicated midrange speaker is some of the worst things ever - just leave it sealed. Also the actual sub driver in Z-4 is a 4" driver, which isn't seen externally (4th order BP with PR instead of port).
So, all in all, I wouldn't touch most of Logitech speakers - exceptions are Z-3 and Z-2300 which sound quite decent for multimedia speakers, and probably Z-5500 for a cheap home theater.
logitech x-140Hide this!Advertise here!
Logitech Z-680 soundNERD Chip Amps 64 6th November 2012 07:56 PM
Logitech Z-680 B-EAGLE Parts 0 8th August 2008 06:10 AM
logitech z-680 repair Catfish45 Everything Else 1 7th July 2008 05:40 PM
FS: 62W logitech Drivers kderedwolf Swap Meet 8 29th April 2005 04:00 AM
Copyright ©1999-2017 diyAudio
