I have built an unpowered 2 way speaker recently with a simple biwire input.
I was wondering if there were any leads that were biwired at one end and had a 3.5mm jack at the other end? If there is such a thing, would it be possible for it to plug into my computer and play to sufficient volume solely of the power of the computer? or would I need to get another amp? |
#2 |
Hard to find such a cable/connector combo I believe.
The computer 3.5mm output is either line level or a headphone out. The line is not for speakers and neither is the headphone out. You will get some sound from the headphone though but it will be distorted and only at very low volume. You need an amp meant to drive low impedance loads. /Peter |
#3 |
it is a speaker output (the green output)
#4 |
when you say its not for speakers do you mean ones that dont have inbuilt power supplies?
#5 |
Well I don't what what kind of computer you have but it's not very common with power amplifiers in computers.
The color wouldn't tell me a yota unfortunately. The computer has a powersupply, otherwise it wouldn't work, but the audio outputs are most likely those that I mentioned and not speaker out. I have never heard about or seen a computer with a built in power amp. /Peter |
| do i REALLY need a crossover?? and an amp question. and an ohm question | legendaryfrog | Multi-Way | 4 | 29th October 2006 01:39 AM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| DCX2496 connectivity problems | MtBiker | Digital Line Level | 0 | 15th June 2005 02:51 AM |
| PS question - tformer question actually | breguetphile | Chip Amps | 2 | 30th May 2003 01:29 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.08185 seconds (76.66% PHP - 23.34% MySQL) with 10 queries |
