Old 15th April 2008, 05:04 PM   #1
morfius is offline morfius  United Kingdom
Default Xmax Question
When speakers list there xmax as say for example 6mm, does this mean its excursion is 6mm either way from center.
i.e. its excursion is 12mm from both extremes.
Old 15th April 2008, 05:38 PM   #2
It depends whether they are lying or not, should be one way, often bothway.
/sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 15th April 2008, 05:45 PM   #3
sdclc126's Avatar
Yes - I don't think manufacturers are consistent about this - you should try to contact the manufacturer to specify halfway from center or total cone travel - hopefully they will tell you.
Soft Dome
Old 15th April 2008, 08:18 PM   #4
Excursion Xmax is defined one way.
But i agree you can't rely on how
manufacturers see this ...
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 15th April 2008, 09:22 PM   #5
tinitus is offline tinitus  Europe
If its peak to peak you often see the addition (p-p), and even (+/-) if its one way...but not always I think like linearray that Xmax without further specs is one way, or should be
Old 15th April 2008, 09:26 PM   #6
ente is offline ente  Germany
Default ARTA 1.4
... if you are eager to learn something about linear excursion contact W. Klippels homepage. There is a lot of stuff about it
http://www.klippel.de/pubs/papers.asp
After reading you can decide if manufacturers are lying or not
Heinrich
PS: Next version of STEPS from ARTA-family will content a Klippel module for measuring Xlin. Have a look on the ARTA Homepage at the end of the week:
http://www.fesb.hr/~mateljan/arta/index.htm
Linkwitz's Xmax calculator question cuibono Multi-Way 4 3rd February 2009 08:14 PM
Question about xmax mitchyz250f Subwoofers 12 2nd August 2008 08:02 PM
Xmax dallaire Multi-Way 2 25th December 2007 09:47 AM
Xmax Question jwatts Multi-Way 13 5th February 2005 12:11 AM
Xmax mik Subwoofers 12 1st December 2004 04:39 AM
Page generated in 0.09022 seconds (73.35% PHP - 26.65% MySQL) with 10 queries
