#331 | |
#332 | |
BTW I have to say that after many experiments I grew tired of any kind of stereo and I am finally fed up with all those pseudo-real effects I still have two spekaers suitable for CFS but I use only one It all started by accident (when a kitten destroyed one of the speakers) but when after a while and fixing the problem I was able to go back to stereo I have discovered to my own suprise that I am unhappy with it, that I had enjoyed the music better earlier in mono (in the CFS configuration of course) so I am definitely into mono now and I have to say that I am really happy listening exclusively to the MUSIC itself again I know and in fact I experience that not every stereo recording sums into mono well but it bothers me less then distracting stereo pseudo-realistic effects should be the best felt is very effective and very linear AFAIK, I haven't got the numbers before my eyes but IIRC 5<10 cm of felt gives 90% reduction of reflected energy in broad spectrum 500 Hz< |
#333 |
In fact I did not mark the positions of the speakers, but placed them more or less at the same places from my memory. Now I did the positioning with measurement and found the imaging is dependent on
1) single peak reflection 2) same reflection pattern on both channels So I was able to get almost the original behaviour again. "Almost" because I couldn't get rid of the two-peakiness completely and this could be due to the foam. I don't know yet whether I will be fanatic enough to replace the Basotect by wool felt, the result is good enough now. What I find weird is that the reverb algorithms work much better in an asymmetric environment. Last edited by el`Ol; 1st February 2010 at 10:23 AM. |
#334 |
The ceiling firing Ciare HX160 is an excellent mono driver. Originally I planned to use it as CFS in hm's Lure backloaded horn (simulates well). The problem was that two of them still played mono, so I discarded this idea.
#335 | |
What is your subjective sensation? "They (sounds) are here" or "you are there"? |
#336 |
With the felt the reflection was shorter and had no repetition. With careful placement now one can't really see two peaks but on can see the reflection consists of two (united) parts that look very similar. To reliably say whether there is an audible difference one would have to do A-B comparison, maybe I believe to hear a difference because the measurement is different. I think there was better focus before.
With synth acoustic I neither have the feeling of being there nor of they are here because it differs much from the natural impression. Just some kind of "envelopment", audible stereo panorama and inaudible speaker positions. |
#337 |
"so I am definitely into mono now and I have to say that I am really happy listening exclusively to the MUSIC itself again"
that would not work for me, I tried many times, every time I get great speaker, but only one, for instance big old Altec coaxial, or Trusonic coaxial ... each time I try listening in mono, everytime there is something missing, its like looking at the world with one eye only, suddenly whole space perception is gone, the same with mono, putting left anf right signal together just eliminates many fine nuances of music, plus in stereo its much easier to recognize and follow each instrument separately, especially in good live two mic recordings mono? no thanks, its a step back ed |
#338 |
#339 | |
it is not at all like conventional mono ie. with two speakers or with one speaker pointing directly at the listener "space perception gone", "elimination of fine nuances", more difficult "to recognize and follow each instrument" - it is all true with regard to conventional mono but it is not at all true with regard to CFS mono the only thing missing is left-right extension of the auditory event in fact I find it easier to recognize and follow each instrument and to follow fine nuances in CFS mono than in stereo and I think that it can be explained by the lack of distracting pseudo-real stereo spatial cues which confuse brain Last edited by graaf; 1st February 2010 at 02:22 PM. |
#340 | |
If you want real envelopment - and not only an unforeseeable spaciousness effect from strong room reflections - mono plus 2 surround channels at 90° would be more capable of delivering a realistic spatial sensation. But again, you'd need special recordings which are not available although 5.1 or 7.1 surround recordings would be suitable (because of the un-EQed center channel). But then, why omit the spatial information stored in the L and R channels? Best, Markus |
| loudspeakers and room interaction | jlo | Multi-Way | 1 | 25th July 2007 08:17 PM |
| measuring in-room response of speaker system | cporada | Multi-Way | 0 | 1st November 2005 04:50 PM |
| multiple room system on the cheap | bser | Multi-Way | 14 | 17th April 2005 08:35 PM |
| Room coupled loudspeakers? | suprf1y | Multi-Way | 9 | 27th November 2004 09:25 PM |
| open baffle loudspeakers and room size | Russell Sit | Multi-Way | 29 | 7th July 2004 04:44 AM |
| Page generated in 0.15871 seconds (81.73% PHP - 18.27% MySQL) with 11 queries |
