The Advantages of Floor Coupled Up-Firing Speakers - Page 7 - diyAudio
Old 22nd April 2008, 12:45 PM   #61
Colin is offline Colin  United Kingdom
TJ mentioned it in one of his later articles for HFN and I've read other people come to the same conclusion.
Old 22nd April 2008, 02:51 PM   #62
graaf is offline graaf  Poland
graaf's Avatar
so perhaps this is REALLY the way to go
I mean not to try to mask (acoustically) the room but rather to mask the speakers instead.
in other words not to take the room out of the "sound equation" but the speakers instead
best,
graaf
"high phooey and hystereo" - Yascha Heifetz
Old 22nd April 2008, 03:19 PM   #63
49 - for the 19th time!!!
c2cthomas's Avatar
See attachment - Problem solved! Now I can lay down on that mattress we discussed in an earlier post and take that nap!!
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 22nd April 2008, 03:38 PM   #64
graaf's Avatar
sweet dreams!
Old 22nd April 2008, 09:02 PM   #65
how about front horn enclosure placed in the corner, closely coupled to walls. whole room would work as horn.
Old 22nd April 2008, 09:21 PM   #66
el`Ol is offline el`Ol  Germany
And in this position the second matress hanging above you will get much closer to your head, dramatically increasing the channel separation, while being close to the floor liberates you from many room mode problems.
Do some recordings with this and it will be heaven on earth:
http://www.thomann.de/de/haun_mbnm62...enzflaeche.htm
Old 22nd April 2008, 09:27 PM   #67
Brett's Avatar
Like a Klipschorn?
Old 22nd April 2008, 09:29 PM   #68
graaf's Avatar
great idea!
and absolutely worth trying
it would be not so much different from Carlsson OA-52 positioned in the corner
and perhaps even better
best,
graaf
Old 22nd April 2008, 09:32 PM   #69
graaf's Avatar
Originally posted by Brett
Like a Klipschorn?
a bit different
but I agree that Klipschorn and other corner horns (Lowther et a.) are viable alternative methods
I've already said above:
high directivity speaker in (or close to) a room corner and significant toe-in is also a reasonable method of dealing with early relfections, of "speaker-room interface", like in case of classic corner horns
best,
graar
Old 22nd April 2008, 09:38 PM   #70
c2cthomas's Avatar
Very nice MisterTwister!
I am working on similar idea but using Ted Jordans line array concept - corner placed - waveguide baffle - 2 JX6 speakers per array.
Perhaps with this sound card to tune things with using the PC. http://www.cluboc.net/reviews/sound/...ude/index.asp:
el'O - 485 Euro's - but Thanks for thinking of me
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 03:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 07:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 01:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 09:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
Copyright 1999-2017 diyAudio
