#641 |
CDBurnerXP is free and works great. I can burn an audio CD straight from FLAC with it.
I don't have any 3D synth music, tho.....
Take the Speaker Voltage Test! |
#642 | ||
Bass to me is tricky. I feel like this is one area where I really don't know what I should be targeting. I think you can get different kinds of bass depending on transient or lack of transient information being conveyed in the playback system. You will see fans of dipoles talk about it. But I think there can be this overly punchy bass from speakers and also a sort of hazy bass that is more "roundish" or "O-ish" Quote:
Common - I Am Music Medeski, Martin, and Wood - Midnight Poppies/Crooked Birds I usually use foobar 2000 to convert lossless to wav and then just use EAC with a cue sheet to burn the CD. If you have your CD drive setup with the proper read offset and write offset and you are ripping securely your back up copy should be a 1:1 exact copy. |
#643 |
To make one thing clear:
I am not publicly outing myself here as someone who wants to "steal" music. As the icon implies I was indending to throw it in the bin after testing. But meanwhile I have a much easier solution anyway: My kitchen radio has chinch outputs and I will connect it to my system. I have no FM receiver in my system because the Bavarian classical channel can only be received at bad quality in my region and satellite radio is a mess anyway. But I can listen to a pop channel and compare the various songs. Why do it easy when you can have it complicated. |
#644 |
One has to note that there are alot of different styles of synth reverb up to reverbs that are sampled from real spaces and are probably not distinguishable from the real ones. As for samples, why not check out the manufacturers demo pages?
I like the sound of this one: ArtsAcoustic | because sound matters |
#645 |
Thanks a lot for the link. I will try it. Very good is that they say the algorithm doesn't contain convolution. Probably it is a bit vague when they say a reverb eats a lot of CPU. David Griesinger (the one from Lexicon) writes that the main problem is the memory access that is much more efficient in his custom chips.
#646 |
I want to add, just in case, that all reverbs do basically the same thing. They layer delayed copies of the original signal (thats why one can build reverb like sounds with simple echo effects if one shortens the delay enough). Sometimes, the copies are eq'ed or filtered. Even a convolution reverb doesnt do different, just the pattern of when which sound is played is copied from a natural source. Synthetical reverbs usually achieve these patterns with feedback networks.
#647 |
Yeah Arts sounds great but is a real CPU hog. I always thought it was convolution but I never used it much or read the manual.
I agree MaVo most all reverbs are delays with filtering and a little bit of psychoacoustic magic thrown in there. |
#648 |
#649 | |
There was one thing however I found very strange: The sources are moving extremely when my head moves, a matter of centimeters. I listened to the examples of the Quantec Yardstick (the new one with roomsize parameter) some time ago, I think I have written about it earlier in the thread, and in contrast I found that especially the more wet examples sounded more like real rooms. But this algorithm is so CPU-eating that there is still no PC that could handle it alone. I am not going to visit the sites of all reverb manufacturers, but I now believe Markus that mastering can do a lot of harm. BTW, Markus, are you still around? It would be nice if you could tell us something about these "esoteric effects"? I think when the term "mastering" is used most of us only think about compression. |
| Floor Standing Speakers. | gurpreetsingh | Full Range | 11 | 12th June 2012 06:42 AM |
| side/ rear firing speakers Good/Bad? | mcmahon48 | Multi-Way | 1 | 6th February 2009 12:28 PM |
| How far can the driver of a down-firing sub be from the floor? | The Paulinator | Subwoofers | 11 | 16th May 2007 08:10 PM |
| Using a diffuser cone for up-firing speakers | tspringer99 | Multi-Way | 15 | 24th January 2006 03:56 AM |
| Woofer: side firing pair vs front firing? | tcpip | Multi-Way | 13 | 9th September 2005 02:13 PM |
