#581 | |||
orthodox-unorthodox - lexical question, perhaps I shoud have used another description eg. unconventional ![]() but as I can see it in substance we agree, because You wrote: Quote:
"high phooey and hystereo" - Yascha Heifetz |
#582 | ||
that "we still try", that "We just don't know yet" or that: Quote:
All I would like You to do is to decide on Your position - is it "we just don't know yet" or is it "In the light of facts only one approach is reasonable"?
#583 |
There's nothing to decide. These two topics are not mutually exclusive.
#584 | |
Dan edit: sorry, Markus got his post in first. |
#585 |
Right now Im listening to 3way dipole "setup"
Actually, drivers are just placed on the floor, on their magnets Its kind of omni, I would say Should I do another "omni", it would most likely look very much like Carlson Mind you, not the old vintage, but the later mr Carlson(Sweede) Which means ALL drivers placed close to floor, but slightly angled Funny thing is that despite the drivers are positioned close to the floor, soundstage seems quite normal in height |
#586 |
If you like the sound coming from the floor...
#587 |
I expected that too, but it sounds perfectly normal
Quite surpricing, yes Very precise and correct actually Apart from the drivers jumping when I play loud, and loose items moving Yes, I have to conclude theres potential in placing drivers close to the floor, if done correctly |
#588 |
Define "normal".
#589 |
Like when you "see" the musicians placed at same height as you when you sit listening
Whether thats correct is debateable, but its the only option we can perceive as acceptable Maybe ideally slightly above Ofcourse there also need to be some effects coming from other than an exact point, to give some sense of "room" I suppose thats what you call ambience But to me, the source of sound, meaning the musician, should always be placed accurately, and pin pointed And I mean ALL musicians in a band All this ofcourse also relates to distance from speakers Im sitting about 3 meters away A bit more would be better, but then I would need speakers to be wider apart also I prefer distance between speakers to be equal to listening distance |
#590 |
Right now I'm experiencing my first satisfying stereo experience in my residence--which I've been doing most of the day. I've searched long and hard for such a beast and found it by copying some ideas from Dr. Geddes. I put together some drivers that would achieve something like constant directivity from 1kHz to 20kHz (I couldn't reasonably build better)and aimed them to cross in front of me by about a meter so that the lateral reflection would hit my opposite ear judging by and of incidence equals the angle of reflection. Maybe the real reason this works is because the the smoothest part of the tweeters response is on axis with the ear now.
There is something to his madness and sensibility for his confidence in the approach. Now I'm thinking he might not be crazy with his approach to bass.![]() ![]() Has anyone heard a similar system done with an OB woofer? Dan |
| Floor Standing Speakers. | gurpreetsingh | Full Range | 11 | 12th June 2012 06:42 AM |
| side/ rear firing speakers Good/Bad? | mcmahon48 | Multi-Way | 1 | 6th February 2009 12:28 PM |
| How far can the driver of a down-firing sub be from the floor? | The Paulinator | Subwoofers | 11 | 16th May 2007 08:10 PM |
| Using a diffuser cone for up-firing speakers | tspringer99 | Multi-Way | 15 | 24th January 2006 03:56 AM |
| Woofer: side firing pair vs front firing? | tcpip | Multi-Way | 13 | 9th September 2005 02:13 PM |
