#452 |
erased quotation from Floyd Toole wasn't "on topic"?
![]() I ask because before typing it in again (I haven't it in digitalized form so I can't just copy and paste) I would like to know whether it violates forum rules Can I ask Markus whether He tested "Beolab 5" speakers (or just gave them 5 minute listen somewhere) before concluding that they are "one of the worst" or will it be regarded as "personal argument"? I would just like to know the rules. I desire to obey them.
"high phooey and hystereo" - Yascha Heifetz |
#454 | |
I listened to the Beolab 5 at the B&O shop in Munich, Maximilianstrasse. The speakers were set up symmetrically about 50cm from the front wall. I was sitting on a leather couch in about 3m distance. The room opens to a larger space behind the sofa. We closed all windows to minimize noise and calibrated the speakers. I had CDs with me that I'm very familiar with and listened about 45 minutes. The sound was non-transparent. Very hard to listen through the recording and to follow single instruments. Localization was ambiguous. A huge "cloud" of sound, a creamy soup instead of a minestrone. The bass calibration was disappointing - there were still huge modal peaks, overall bass level was too low and a serious lack of energy below 50Hz (the speaker is advertised "EFFECTIVE FREQUENCY RANGE 20-20,000Hz"). |
#455 | |
an interesting patent and AES-paper:
Patent US4496021 AES E-Library: Loudspeaker Directionality and the Perception of Reality what makes it interesting is not so much the "orthospectral tweeter" itself but some statements in the "background of the invention" section - see image attached those statements seem to give basic theoretical explanation for Linkwitz's "wall effect" see: ORION++ Quote:
"high phooey and hystereo" - Yascha Heifetz Last edited by graaf; 22nd February 2010 at 10:04 AM. |
#456 |
This doesn't explain anything. The influence of reflections is not fully understood. Everybody is guessing and declares his own experience the truth. This dogmatic approach to small room acoustics is most evident in the history of control room design (see Jan Voetmann "50 Years of Sound Control Room Design", AES Convention Paper 7140).
Toole himself asks the right questions in his AES paper "Loudspeakers and Rooms for Sound Reproduction—A Scientific Review". There is strong evidence that number, spectrum, angle, level and delay of single reflections are the key. We just don't know yet what the important properties are and how to measure them. Best, Markus |
#457 | |
#458 |
In the light of facts only one approach is reasonable: make the sound field in the listening space similar to the sound field of the original, whereas the original is the sound field of the mastering/mixing room. In my opinion only loudspeakers with high, constant directivity will provide such a sound field in domestic listening rooms that don't allow for major room acoustic optimizations.
How the optimal sound field should look like and how recording and mixing techniques would need to adapt is a different discussion. Best, Markus |
#459 |
But with a constant directivity it is virtually impossible to make the first reflections the same as the direct sound. Since the bass will be omni and the treble directional the bass will always be reflected back at you before the highs and will not be the same spectral balance. An omni will make the reflection times shorter but remains roughly the same spectral balance regardless of which angle is reflected at your ear first.
#460 |
Wrong, only constant directivity will make the indirekt sound field similar to the direct sound.
Earl describes it in more detail here: http://www.gedlee.com/downloads/directivity.pdf |
| Floor Standing Speakers. | gurpreetsingh | Full Range | 11 | 12th June 2012 06:42 AM |
| side/ rear firing speakers Good/Bad? | mcmahon48 | Multi-Way | 1 | 6th February 2009 12:28 PM |
| How far can the driver of a down-firing sub be from the floor? | The Paulinator | Subwoofers | 11 | 16th May 2007 08:10 PM |
| Using a diffuser cone for up-firing speakers | tspringer99 | Multi-Way | 15 | 24th January 2006 03:56 AM |
| Woofer: side firing pair vs front firing? | tcpip | Multi-Way | 13 | 9th September 2005 02:13 PM |
