#311 |
yeah, ok!
![]() thanks! |
#312 | ||
#313 |
Anyone who can tell us the percentages (XY, MS, Blumlein pair, 30 cm distance cardioid)?
#314 | ||||
perhaps 90% or even more is multi-miked panpotted stereo? which is not necessarily something wrong per se as stereo principle stays the same as in case of correct Blumlein stereo we should also take into account that audiophile market can differ significantly in that respect it is interesting to know how "true stereo" is understood for instance at Naim, a renowned audiophile gear and record company: http://www.thenaimlabel.co.uk/true_stereo.htm actually their "true stereo" microphone setup looks like so called ORTF and is not "true stereo" as understood by Blumlein and it is simply incorrect from the perspective of theory behind the stereo patent but not as badly as AB-stereo (where no literally no theory explains what is going on) why spaced microphone arrays cannot work properly is explained i.a. in this interesting essay by Robert E. Green: http://www.regonaudio.com/What%20Can...%20Stereo.html also DW "Infotheque" leaves no space for doubt: Quote:
we can read that: Quote:
ORTF is a kind of compromise: Quote:
best regards! graaf |
#315 |
Will have to get this and do my own recordings:
http://www.thomann.de/de/haun_mbnm62...enzflaeche.htm |
#316 |
On the other hand, arenīt boundary microphones built to reduce room resonances and so reduce the "sense for the room"? And does the Carlsson as a "boundary speaker" reduce the sense for the listening room in order to enhance the sense for the recording room?
#317 |
Where should be the boundary microphone ideally placed? On a wall? On the floor? On the ceiling? And what does make any microphone a boundary microphone? My idea of this principle is very vague.
#318 |
hi again!
take a look at those pictures: http://www.diyaudio.com/forums/showt...95#post1634295 http://www.diyaudio.com/forums/showt...97#post1634297 and then at the image I attached to the post No 1 in this thread how about that! ![]() it is nice to see that Mr Linkwitz came to the same conclusion about omnidirectional speaker's placement in small rooms best regards! graaf |
#319 |
another one interesting "corner" speaker (representing an approach a bit similar to short Carlsson speakers):
http://www.gampermartino.com/project...corner-sounds/ best! graaf |
#320 |
Update to the Carlsson project:
After listening to the prototypes for many months I now have the final version running with much better damping inside (rock wool instead of polyester fleece) and outside (Basotect instead of polyester felt). While I am very happy with the tonal improvement I dislike what happened to the imaging. The prototypes had an excellent imaging when fed with real-acoustic recordings and some problems with synthetic acoustic: The instruments were either fixed to the speakers or formed a clump of mud between them. Now the real acoustic recordings are diffuse and without depth, whereas the synth acoustic recordings are much better now and in fact the field where the speakers perform best. I suspect that the basotect is to blame. I held the polyester felt to my ears and found that they have almost complete transmission, so the triangles probably formed reflectors rather than absorbers before. Now I am trying to find a compromise. Thinner Basotect may be a solution, but I would be happy to get rid of it completely because it is very fragile. What about real wool felt? Last edited by el`Ol; 29th January 2010 at 06:46 PM. |
| Floor Standing Speakers. | gurpreetsingh | Full Range | 11 | 12th June 2012 06:42 AM |
| side/ rear firing speakers Good/Bad? | mcmahon48 | Multi-Way | 1 | 6th February 2009 12:28 PM |
| How far can the driver of a down-firing sub be from the floor? | The Paulinator | Subwoofers | 11 | 16th May 2007 08:10 PM |
| Using a diffuser cone for up-firing speakers | tspringer99 | Multi-Way | 15 | 24th January 2006 03:56 AM |
| Woofer: side firing pair vs front firing? | tcpip | Multi-Way | 13 | 9th September 2005 02:13 PM |
