The Advantages of Floor Coupled Up-Firing Speakers - Page 318 - diyAudio
Old 17th September 2013, 11:35 AM   #3171
graaf is offline graaf  Poland
graaf's Avatar
next to be tested:
Originally Posted by graaf View Post
interesting "no direct sound" placement method: Stereo Unlimited tweak
below is what I am talking about (please take A CAREFUL NOTE OF the db scale! ):
Originally Posted by Elias View Post
I think it results hole in the middle. Side wall reflections arrive in very wide angle, AND there is no strong center sound.
it depends on the stereo triangle in the room geometry and in particular on the toe in of the dipole null axis in the direction of the listener
with the right geometry there is a center sound - in form of reflections from the front wall
"high phooey and hystereo" - Yascha Heifetz
Old 18th February 2014, 12:41 PM   #3172
graaf's Avatar
generally it appears to be a consensus in literature that frequency range critical for localisation perception is >0.5 kHz
I suggested above (and with some good reasons I believe) that the important range extends roughly 0.4<4.0 kHz
Originally Posted by daniel View Post
it is desirable to have 0 phase rotation of the harmonics, Griesinger showed a reason why. It all comes down to separating individual sound-streams in a 'busy' environment - coctail-party-effect. This is most effective when the harmonics have the same time-delay, so that the waveform doesn't get smeared.
Originally Posted by gedlee View Post
The phase needs to have constant group delay from 700 - 7 kHz as Griesinger says
Old 18th February 2014, 07:53 PM   #3173
Graaf,
The three quotes you listed in #3172 are all good reasons not to point speakers at the ceiling.
Old 18th February 2014, 08:41 PM   #3174
graaf's Avatar
is that so? why?
BTW new Swedish flooder:
OD-11 - Teenage Engineering
http://assets.sbnation.com/assets/19...D-11_Flyer.pdf
Old 19th February 2014, 06:18 AM   #3175
graaf's Avatar
Originally Posted by weltersys View Post
Graaf,
why?
Exactly what is wrong with lowering the level of the floor reflection at the expense of a higher level of the ceiling reflection?
What does it have to do with phase rotation of the harmonics or smearing of the waveform?
Old 19th February 2014, 04:00 PM   #3176
Graaf,
why?
What is wrong with less floor and more ceiling reflections is I find it preferable to have floor and ceiling reflections to appear naturally as they would in a normal presentation. Your preference is quite different.
1)generally it appears to be a consensus in literature that frequency range critical for localisation perception is >0.5 kHz
In either case, the lower range is localized at the floor, upper range from the ceiling reflection.
2)it is desirable to have 0 phase rotation of the harmonics, Griesinger showed a reason why. It all comes down to separating individual sound-streams in a 'busy' environment - coctail-party-effect. This is most effective when the harmonics have the same time-delay, so that the waveform doesn't get smeared.
Again, upper harmonics, being more directional, are reflected from the ceiling, while fundamentals are heard from both floor and ceiling, multiple different delay times.
3)The phase needs to have constant group delay from 700 - 7 kHz as Griesinger says
Phase relationships and group delay are not maintained when the first arrival times are multiple reflections. The upper range, 700-7 kHz is most smeared, as most speakers are more directional in that range.
Art
Old 24th February 2014, 05:35 AM   #3177
TNT is offline TNT  Sweden
Originally Posted by Juhazi View Post
A funny thing.. I... Sonab OA-13. .
Please a picture? I don't think there ever was model called that.
Old 24th February 2014, 08:27 AM   #3178
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Oops, mine are OA-14, teak veneer. Bass drivers have been changed but tweeters are original. They are at my summer cabin and I have not had enough interest to update tweeters.
CarlssonPlanet.com &bull; Sonab OA-14
AINOgradient speaker project
Old 24th February 2014, 09:56 AM   #3179
Juhazi's Avatar
^but old Carlsson/Sonab speakers are not floor, but wall coupled! The bass driver is placed close to the wall. Bass reflex port is downfire and it can be called floor-coupled.
Old 24th February 2014, 10:19 AM   #3180
graaf's Avatar
it depends, short Carlsson speakers like OD-11, OA-52 or V-1 can be said to be floor-coupled
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright ©1999-2017 diyAudio
