The Advantages of Floor Coupled Up-Firing Speakers - Page 227 - diyAudio
Old 3rd May 2013, 09:58 AM   #2261
Originally Posted by wesayso View Post
Isn't it true that a lot of mixing/mastering is done on nearfield monitor speakers? And yet most reproduce the music in the farfield on most speakers. Line arrays keep you in that nearfield and remove the floor/ceiling reflection.
What's wrong with that?
mixing and mastering is done on a variety of speakers and in a variety of environments - including cars. This is done to make sure the final mix sounds good even on a boombox.
Old 3rd May 2013, 10:53 AM   #2262
wesayso is offline wesayso  Netherlands
wesayso's Avatar
I know, but I got tired of reading that argument about the equipment used in the mixing stage. Surely we don't have to buy that same range of speakers they used in their process?
Old 3rd May 2013, 12:30 PM   #2263
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by Soundtrackmixer View Post
Since we don't use on/in wall line sources anywhere in the mixing or mastering workflow(whether music only or movies), then playing music or a soundtrack back on FCUFS is nothing more than a "effect" that is all. Much like bipolar, and Bose 901's are "effect" speakers as well. It is not representative of anything used in the mixing and mastering workflow.
what about Don Keele's CBTs? Do You consider them unsuitable for HiFi applications? Because You won´t find anything like them in studios. And they are even a bit flooder-like
"high phooey and hystereo" - Yascha Heifetz
Old 3rd May 2013, 12:35 PM   #2264
graaf's Avatar
Old 3rd May 2013, 03:27 PM   #2265
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by graaf View Post
Do You know any???
I do, because I have tried flooder.
I think the most notable disadvantage is a lack of pin-point-imaging (HiFi term). The images are bigger than pins with flooder and bigger than what one may have been used to with conventional speakers. Flooders are no suitable for keyhole peekers.
That said, there is another issue, even more severe. If one wishes to satisfy his audiophile desire to listen to his loudspeakers it does not go ! Because the speakers are no longer perceived as sound sources. What a disaster !
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 3rd May 2013, 04:21 PM   #2266
I didn't say anything was unsuitable, I distinctly said it was an "effect".
Can you understand the difference?
Soundtrackmixer - M.P.S.E/AES/SMPTE member
Old 3rd May 2013, 04:27 PM   #2267
I cannot tell you how wrong you are on this. Yes the speakers we mix and master on are from different manufacturers, but their design is similar. They are front firing speakers like 99% of the homes have in their listening rooms.
I have never heard of a single mix done in a car. What we use to simulate a car speaker is a one driver box speaker sitting on the edge of the console.
While studio's have different sizes, their shapes vary between a box to a rectangle. We don't mix in round studios, octagons, or any other shape. The results would be far too unpredictable
Old 3rd May 2013, 04:31 PM   #2268
If you bought a front firing speaker, then you have already bought the same range of speakers used in mixing and mastering. It is the technology, not the different manufacturer that is the issue here.
Let's face it. I know of no studio that uses a flooder to mix or master audio. I know of no Bose 901 or any other speaker that uses a majority of reflections as part of its dispersion pattern used in mixing or mastering. So if you play audio back on these types of speakers, you are creating an "effect" and that is it.
Old 3rd May 2013, 04:53 PM   #2269
Unless you have a very, very large room, you are listening in the nearfield. AES defines nearfield as anything less than 10ft away. Not many here have a listening room that allows them to hear their speakers from 10ft or more away.
Old 3rd May 2013, 05:00 PM   #2270
And since I don't treat my listening room like a mixing room, I can't hear music at all? You can find mixing/mastering rooms with all kind of speakers including dipoles like Martin Logan. I haven't seen any flooders though, but who cares.
You can do whatever the heck you want to do, it is your room and your system.
I think your point here is pretty damn weak. The lion share of speakers in recording studios, tracking studios, editing studios, and mastering studios are front firing cones and domes. Not Martin Logans, and not dipoles. Why? Because the overwhelming majority of people purchase front firing cones and domes, not Martin Logans or dipoles.
Overreaching your point shows there is a definite weakness in it.
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright ©1999-2017 diyAudio
