The Advantages of Floor Coupled Up-Firing Speakers - Page 225 - diyAudio
Old 30th April 2013, 05:12 PM   #2241
Originally Posted by graaf View Post
What is ridiculous about it?
It is just psychoacoustics.
If you say so
And it has been confirmed in the "Archimedes" Eureka-funded scientific research project I linked above.
Has this been peer reviewed? Has it been submitting to AES or any other organization? If not, its validity is questionable and untested.
Ceiling reflection is detrimental to the sound quality of a conventional forward firing speaker but it affects quality in a different way than floor reflection.
It is the floor reflection that destroys the sense of realism:
That last statement is pure crap, and this is where you lose credibility with me. A floor bounce is so apart of our everyday hearing we have largely learned to ignore it. Ceiling bounces are a different story entirely. We have not learned over time to use the ceiling or sky as a way of determining direction like we have the floor. As a matter of fact our ears do very poorly at determining direction coming from above our heads.
As Pano has stated, if you like the flooder system that is one thing. But to snow job the rest of with these crappy theories is just plain annoying.
Soundtrackmixer - M.P.S.E/AES/SMPTE member
Old 1st May 2013, 09:38 AM   #2242
graaf is offline graaf  Poland
graaf's Avatar
and this is exactly my point, this is exactly why FCUFS work! Canīt You see?
"high phooey and hystereo" - Yascha Heifetz
Old 1st May 2013, 03:09 PM   #2243
Yes I can see....I can see BS when I read it. If this is supposedly the best approach how come nobody has endorsed it except this one study? Why are there are no commercial products, or any peered reviewed papers that support it? How come what I have read from Toole's work does not support anything I have read from you in this thread? Or any work I have read since I started in audio?
Yes I truly see the nonsense here.
Old 1st May 2013, 03:46 PM   #2244
vacuphile's Avatar
Graaf,
Interesting topic.
I only read the beginning and the last few pages of this thread, but has somebody already mentioned that it is interesting in that it is the reverse of a boundary effect microphone?
boundary microphones | boundary mics
An FFT of my life would show a couple of peaks and some low level harmonics, but mainly random noise.
Old 1st May 2013, 04:25 PM   #2245
Banned
Which study? There is no conclusive study that established the fact that a speaker on the floor is the best thing since sliced bread.
Sure, the floor bounce might be a distance cue (revealing the location of the speakers) and loud first reflections (from the ceiling) can override earlier localization cues (e.g. from the direct sound) but those are pretty weak arguments for putting a speaker on the floor.
Old 1st May 2013, 07:23 PM   #2246
Of course you are right, and that was my point exactly. I was referencing this comment
I agree. My next question is how can a track mixed and mastered on a front firing speaker translate well to a speaker sitting on the ground and firing upward? I cannot see this working very well, just like movie soundtracks sound overly diffused played back through bipolar speakers
Old 2nd May 2013, 07:37 AM   #2247
Elias is offline Elias  Finland
Elias's Avatar
I was looking for the loudspeakers and room system thread, and wtf ?!?
So, advantages it shall be ? Is it allowed to disscuss any disadvantages of flooders in this thread
oh c'mon Elias! what cues? Consider the system as a whole ie. the floor coupled speaker AND its ceiling reflection - HRTF? Consider that we have here high freqs BOTH from below and from above
It is possible to mask the origin location of the source by presenting relatively strong almost simultaneous reflections to the listener in addition to the direct sound.
But how does this relate to goodness or badness of floor reflection ?
the difference is caused by the fact that a ceiling/coming-from-above reflection is not - unlike a ground/floor reflection - a spatial cue per se
So in your theory above sounds are no cues ? Do you locate birds singing flying above to the horisontal plane ?
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 2nd May 2013, 07:52 AM   #2248
Elias's Avatar
Take into account that this same thing is exactly the case with stereo itself ! There is no similar situation in nature like 2 sound sources in 60 deg angle emitting the same sound at the same time. The reason some people hear phantom images in between the speakers is due to lack of adaptation to this effect in nature during the past millions of years. If our hearing would be accurate, we would be allways hearing 2 speakers in their exact locations.
It may very well be that due to lack of adaptation of ceiling sounds in nature, there is similar effect taking place like in phantom imaging. It is possible, that ceiling sounds can be used as a tool to generate effects. Why not to take the possible benefits out of it.
Old 2nd May 2013, 08:17 AM   #2249
Elias, when stereo vinyl came on the scene, engineers already knew that two channels was not enough for good soundstaging. However, we have managed to get fairly decent sound from two channel as a result of years of experimentation and experience. Flooders do not have that level of long term experimentation behind it, as a matter of fact you cannot even find information on flooders when you google. Our familiarity with two channel allows most of us(myself not included though) to ignore the drawbacks, and adapt to what is there.
Do I really want an "effect" or do I really want to hear what is on the media? I am more of a latter guy than a former guy. Since I am not a hater, I respect if somebody likes a bit more seasoning than I do.
Old 2nd May 2013, 09:58 AM   #2250
Elias's Avatar
In theory 2 media channels are enough for 2 eared listeners. More than 2 media channels is unneccesary and completely redundant. It is just the matter of generating ear canal signals from those 2 channels. That is of course the difficulty, how to do it. Stereo triangle is one method, headphones another, there are other methods too.
The number of loudspeakers is not restricted to the number of media channels.
But here is the point, two speaker stereo triangle does not provide you with "what is on the media". At the listening position there is gross amount of comb filtering due to interference field from the two speakers. The difference of a real source in the center and the phantom image is the comb filtering (among others). The comb filtering pattern is not on the media, it is of cource created by stereo triangle.
Flooders do one thing good, they can help to overcome this basic flaw of stereo triangle. By adding multible of room reflections the annoyance of comb filtering is decreased. Also the sweet spot is much bigger (also related to interference field). In addition head movements no longer affects the perceived sound, the head can be turned and moved freely.
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright Đ1999-2017 diyAudio
