The Advantages of Floor Coupled Up-Firing Speakers - Page 221 - diyAudio
Old 27th April 2013, 06:22 PM   #2201
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by graaf View Post
while in the flooder approach speaker configuration creates no elevation cues of itself, therefore only those elevation cues that are preserved in the recording are audible
How so ? If the sound is coming from the ceiling reflection, then all the elevation cues are ceiling cues.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 27th April 2013, 07:45 PM   #2202
+1,000,000
The problem that I am having with this "flooder" thing is that no studio mixes on a flooder type system. So this becomes a sonic gimmick with absolutely no point of reference whatsoever. It is an effect, and nothing more.
Soundtrackmixer - M.P.S.E/AES/SMPTE member
Old 27th April 2013, 09:49 PM   #2203
graaf is offline graaf  Poland
graaf's Avatar
oh c'mon Elias! what cues? Consider the system as a whole ie. the floor coupled speaker AND its ceiling reflection - HRTF? Consider that we have here high freqs BOTH from below and from above
"high phooey and hystereo" - Yascha Heifetz
Old 27th April 2013, 09:55 PM   #2204
graaf's Avatar
Originally Posted by Soundtrackmixer View Post
+1,000,000
so it is a real thing, isnīt it? You call it "an effect" but isnīt "stereo" itself "an effect" either? So - is it the only problem You're having with this "flooder" thing?
Old 27th April 2013, 11:30 PM   #2205
Please don't BS me, it weakens your arguement. Almost all music is mixed and mastered on front firing stereo speakers. By playing the music back on a flooder system, you are totally changing the presentation and the carefully eq'd frequency response the mastering engineer was trying to create.
All studio use either stereo or multichannel speaker setup with front firing speakers. Nobody uses a flooder.
Old 28th April 2013, 02:34 AM   #2206
Pano is offline Pano  United States
Pano's Avatar
You'd think Muzak would, considering.
Old 28th April 2013, 05:42 AM   #2207
Ronion is offline Ronion  United States
Looking at a Picasso through 3D glasses can be fun. Pretty sure i'd want to see one in its original setting though.
Old 28th April 2013, 06:16 AM   #2208
graaf's Avatar
Are You trying to be rude, this time? You almost succeed. Are You proud of Yourself?
Old 28th April 2013, 06:33 AM   #2209
graaf's Avatar
The presentation is more realistic. Do You think that all unconventional speakers - planar, linesource, omni or unconventional setups like Ambiophonics should be banned from the HiFiland? Also You can Eq the system anyway You like. Audiophiles are doing this all the time. And NOBODY knows the engineer's intention. Most probably not even one listener has a system and acoustics identical to the one used in a studio at home. Probably You won't be able to find two identical studios. Therefore the only true measure of HiFi is the real thing.
Old 28th April 2013, 06:49 AM   #2210
graaf's Avatar
good analogy with 3D glasses! Itīs quite like 3D conversion. But why Picasso?? Think rather about old movies or photos, if such a process was technically feasible.
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright Đ1999-2017 diyAudio
