The Advantages of Floor Coupled Up-Firing Speakers - Page 217 - diyAudio
Old 21st April 2013, 06:07 AM   #2161
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by Elias View Post
Yes, and the focal point of the waveform is indeed at the floor.
not just that, there is more - the sound radiated by the floor level speakers is the loudest and the earliest reaching the listener
yet the sound is not coming from the floor
I think floor to ceiling straight array is better, no floor and ceiling reflections, and the sound is allways coming from your ear height regardless sitting or standing.
- Elias
probably a floor to ceiling line source - like Beveridge - is best, but I am not so sure about a floor to ceiling straight array of discrete elements
"high phooey and hystereo" - Yascha Heifetz
Old 21st April 2013, 10:11 AM   #2162
Elias is offline Elias  Finland
Elias's Avatar
How do we know that ? Maybe it is coming from the floor
If the CBT waveform is really a circular arch focused from a point located at the floor, and if the sound would not be perceived as coming from the floor, it would mean we would not be able to perceive source elevation.
This is not the case since the sound from any point source placed at the floor and aimed to the listener is perceived as coming from the floor.
Then how is CBT different in perceptual sense ?
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 21st April 2013, 03:58 PM   #2163
maybe it's just better to fix speakers into ceiling right above listening position
Old 21st April 2013, 07:43 PM   #2164
graaf's Avatar
not when a ceiling is present
http://www.diyaudio.com/forums/multi...ml#post3180924
Old 21st April 2013, 07:46 PM   #2165
graaf's Avatar
because?
I believe that:
http://www.diyaudio.com/forums/multi...ml#post3164641
Old 21st April 2013, 08:44 PM   #2166
Banned
It isn't. The CBT doesn't radiated much energy towards the ceiling. That's one of its main features, controlled vertical directivity. No secondary virtual height source is created. The ceiling reflection simply isn't strong enough.
Old 21st April 2013, 08:46 PM   #2167
Elias's Avatar
But CBT is no flooder, it has vertical beamwidth of only about +-22 degrees. It will not illuminate the ceiling in typical home listening room to provide a strong enough ceiling reflection to lift the image from the floor.
Old 21st April 2013, 08:49 PM   #2168
Elias's Avatar
That's what I was saying
CBT creates images coming from the floor ?
Old 21st April 2013, 08:55 PM   #2169
Banned
Ask Omholt. He has a floor coupled CBT.
Old 21st April 2013, 09:17 PM   #2170
wesayso is offline wesayso  Netherlands
wesayso's Avatar
Put the CBT on it's side at ear height in the corner (maybe a bit in front of the back wall) with the bottom against the side wall, problem solved?
I had exactly the same thought about the CBT and it's floor centred wave front:
Originally Posted by wesayso View Post
Trace back the origin of the sound and you end up on floor level. There is the acoustic center of your (virtual) point source.
That's why I said I would hang it from the ceiling. But I'd rather have a 60 degree version floating between the ceiling and the floor (if you have the space)
http://www.diyaudio.com/forums/newre...eply&p=3434738
But the response of someone that heard it:
Originally Posted by Pano View Post
Maybe in theory, but it never sounded that way to me.
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright 1999-2017 diyAudio
