The Advantages of Floor Coupled Up-Firing Speakers - Page 215 - diyAudio
Old 14th March 2013, 06:27 PM   #2141
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by ScottG View Post
-assuming a "fast" transient in the freq. range.
Even then - almost certainly doubtful.
Why?
ok. ...for 500Hz
just for the sake of moving the discussion forward
then what about 600, 700, 800 Hz?
20 cm, 30 cm, 40 cm etc. above the floor?
any ...tip please?
I do not dare ask for any formula...
"high phooey and hystereo" - Yascha Heifetz
Old 14th March 2013, 08:04 PM   #2142
ScottG is offline ScottG  United States
Originally Posted by graaf View Post
ok. ...for 500Hz
any ...tip please?
-the tip was already provided for reflective conditions vs direct sound: The closer in time, the less effect. The faster the onset, the less effect.
Not much else for me to say on time and "reflections".
Now there might be with respect to time, onset, and intensity with respect to Direct sound.
It might not even be primarily an interaural effect.
perspective is everything
Old 15th March 2013, 08:09 AM   #2143
graaf's Avatar
not the other way round? I mean: The slower the onset, the less effect?
Old 15th March 2013, 07:20 PM   #2144
Context: "reflective conditions vs direct sound:"
The faster the onset, the less effect any reflective condition will have to direct sound.
ie. direct sound dominates with a fast onset.
Old 3rd April 2013, 09:15 AM   #2145
graaf's Avatar
a short review of Shahinian Arc, very favourable:
http://shahinianacoustics.com/63%20shahinian.pdf
Old 4th April 2013, 08:34 AM   #2146
graaf's Avatar
the new Shahinian Larc is the most flooder-like of all Shahinian line, just 34 cm high:
http://www.mikemanningaudio.com/NEWT...rc_Larc650.jpg
Old 4th April 2013, 06:44 PM   #2147
the new Shahinian Arc is the most flooder-like of all Shahinian line, just 34 cm high:
I've heard a few of their designs back in the early '90s - quite flawed in design and execution, yet still capable of *very* nice sound.
One of the worst parts about the design wasn't really a flaw - more of a choice. The use of less efficient drivers for a more broad-band response. It was sort of like Vandersteen meets Spica (except more of a radial configuration than Spica). One of the key audible characteristics was a thick midrange sound, lack of dynamics, and limited spl.
The real problem however is that Ohm's loudspeakers had similar limitations but overall were better sounding for a similar price. (..though most audiophile purchasers at that time couldn't deal with the lack of clarity in the treble from the walsh-type driver.)
Old 12th April 2013, 03:00 PM   #2148
Elias is offline Elias  Finland
Elias's Avatar
There is one branch of flooders completely ignored until now, PA stage monitors
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 13th April 2013, 05:41 PM   #2149
Elias's Avatar
I have very unusual loudspeakers which I have built some time ago with those room-speaker interface things in mind. These are very short omnidirectional loudspeakers. They are just 20 cm high and have 8 inches wide range driver on top and firing upwards.
The loudspeakers are to work on the floor the driver is only 20 cm above the floor and against the wall.
8" coaxial. Could work in flooderish manner when placed on the floor against room side wall, Beveridge way. Tilted top panel helps directing ceiling reflection towards listening position.
Why no one is using in living room ?
Old 13th April 2013, 07:26 PM   #2150
graaf's Avatar
[/IMG]
interesting question, what's Your theory?
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright 1999-2017 diyAudio
