The Advantages of Floor Coupled Up-Firing Speakers - Page 205 - diyAudio
Old 11th March 2013, 08:33 PM   #2041
Banned
Ceiling and floor reflections are on the cone of confusion and therefore might only affect timbre at lower frequencies.
Old 11th March 2013, 09:02 PM   #2042
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by ScottG View Post
-just ask yourself if there is a change in direction at that freq..
That change in direction is the key component of a reflection.
With Elias's example the floor doesn't cause a change in direction at 400 Hz.
Again - can You please post any reference for this?
I mean an explanation when a reflection can be treated as a specular reflection having regard to the wavelength and to the distance to the reflecting surface? Please be so kind. I would be very grateful.
"high phooey and hystereo" - Yascha Heifetz
Old 11th March 2013, 09:28 PM   #2043
Originally Posted by WithTarragon View Post
Cone of confusion refers to the binaural differences. Those will be preserved.
Regarding the issue of similar binaural values for the ceiling and floor reflections: I may might need to disagree with myself. I am still thinking this one through
Old 11th March 2013, 09:53 PM   #2044
Elias is offline Elias  Finland
Elias's Avatar
I'm in the design phase of my new loudspeakers, and exploring the floor reflection contribution therein I made some FDTD simulations of the case.
The simulated waveform is a gaussian wavelet like this:
The simulation includes reflective floor and ceiling. Vertical ends are absorptive. x and y grids are in meters.
Here is 0.8m tall dipole baffle with 12" element at 20cm above floor (to the center) at 500Hz: There got some edge diffraction from the baffle but no distinctive floor reflection.
For reference here the baffle is elevated 1m above floor and element in the center of the baffle at 500Hz: Here a clear floor reflection is seen.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 11th March 2013, 10:11 PM   #2045
Elias's Avatar
Here a snapshot at the time the wave has travelled 3m.
For comparison. 500Hz.
Floor baffle. Nice spherical wavefront. No tail
And elevated baffle. Look at that carbage following the direct sound
- Elias
Old 11th March 2013, 10:33 PM   #2046
ScottG is offline ScottG  United States
I searched a bit, couldn't find anything that was specifically on-point.
Rather than an affirmation, what's the point of diffraction (which does specifically relate to a wave's length and necessarily distance to an otherwise reflective surface)?
perspective is everything
Old 11th March 2013, 10:38 PM   #2047
- Elias
Yup, that's pretty much what *anyone* should suspect.
Old 12th March 2013, 12:38 AM   #2048
It is confirmed. I definitely disagree with my self.
At 0 or 180 degrees (front and back), the binaural cues for the direct sound, ceiling bounce, and floor bounce are all the same. However this is a special case. Off axis the "bounce" will not fall along the cone of confusion (for the direct sound). The binaural cues will differ from each other and also differ from the direct sound. The discrepancy gets larger as the sound source get closer to either of these boundaries.
I have admitted my mistake and I now feel better about myself. Insert smiley face somewhere
Old 12th March 2013, 06:00 AM   #2049
Banned
I have to disagree with myself too. The floor and ceiling reflections are not on the cone of confusion. If the ears would be in the floor plane then the floor reflection would be on the cone of confusion.
For a driver at 100cm from the floor, ear height at 95cm and a speaker distance of 346.4cm the interaural time differences are as follows:
Direct sound: 0.25ms
Floor reflection: 0.21ms
Ceiling reflection (ceiling height 2.4m): 0.19ms
Old 12th March 2013, 07:50 AM   #2050
graaf's Avatar
which means that...? what are the consequences?
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright 1999-2017 diyAudio
