The Advantages of Floor Coupled Up-Firing Speakers - Page 184 - diyAudio
Old 26th February 2013, 10:47 AM   #1831
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by lolo View Post
really? What then the fuss about IACC for hall designs?
IACC is much more complex entity. The result is depending on temporal, spectral and spatial domains. Not just simple ceiling reflection.
How can ITD not change? No difference between a 2.5 high ceiling and a 4m one?
It's simple geometry only. Assume a symmetrical spherical head for yourself, and then draw a cone coincidencing the ears. You'll see the cone surfaces are parallel with the paths from the speaker and from the ceiling reflection.
I thought the worst offender was actually the ceiling, conclusion from the Archimedes project in DK, read it somwhere..
Offender in terms of what exactly ?
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 26th February 2013, 10:54 AM   #1832
Banned
Not sure what exactly you guys are discussing but the delay of the ceiling and floor reflection varies relative to the direct sound with source/receiver position and ceiling height. Please see
Floor/Ceiling Reflection Calculator
Old 26th February 2013, 11:08 AM   #1833
graaf is offline graaf  Poland
graaf's Avatar
floor and ceiling reflections indeed ARE the worst offenders IN CASE of a conventional forward firing loudspeaker
it is VERY true, but NOT in every case
"high phooey and hystereo" - Yascha Heifetz
Old 26th February 2013, 11:10 AM   #1834
graaf's Avatar
- Elias
agreed on both points
Old 26th February 2013, 11:48 AM   #1835
lolo is offline lolo  France
lolo's Avatar
I meant.. Initial Time Delay Gap, not Interaural Level Difference!
Why is IACC not relevant to listening rooms?
Depending on the room, the ceiling is the 2nd offender for the ITD gap.. and not particularly a good contributor to spaciousness. for a direct radiator of course!
Old 26th February 2013, 11:56 AM   #1836
graaf's Avatar
more broadly speaking - for a speaker design which doesn't take it into account - or even better - uses it like in a flooder type speaker, the name of which draws an analogy to a "flood lamp" used for: "Indirect lighting, or uplighting, [which] create[s] a low glare environment by uniformly lighting the ceiling"
exactly what sort of sonic offence do you mean precisely?
I believe that ITD gap is just part of a complex "effect on sound" equation which should be resolved for each and one reflection quite independently ONLY
other important parts of the equation are level, angle and frequency spectrum of the reflected sound
Old 26th February 2013, 12:29 PM   #1837
lolo's Avatar
My ceiling is only 2.2 high.. pure concrete. I suspect it to be responsible for my unhappiness, but wait a couple of weeks so I treat it properly.. and I can then report back.
Old 26th February 2013, 12:46 PM   #1838
graaf's Avatar
with conventional loudspeakers that's very probable
perhaps You could try the flooder approach more thoroughly first, with more suitable speakers
but it's up to You of course
Old 26th February 2013, 12:49 PM   #1839
lolo's Avatar
I will, but give me time, I am cheap... and broke!!
The drivers I have at hand now are not suitable. Also bear in mind that I get almost exactly what I want from the dipoles..
Old 26th February 2013, 01:08 PM   #1840
graaf's Avatar
my suggestion - try some s/h coaxial minimonitors by Kef or Tannoy
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright 1999-2017 diyAudio
