The Advantages of Floor Coupled Up-Firing Speakers - Page 182 - diyAudio
Old 25th February 2013, 08:28 AM   #1811
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by Elias View Post
I'm using something remotely similar in my current test setup !
I have 3 ceiling firing speakers lifted at almost ear height, and they are driven by linear stereo matrix of x=0.5.
- Elias
so combination of a tall flooder plus matrix of 0.5
interesting evolution of Your concept!
what sort of speakers You use? how tall? The Direct Acoustics speakers are acoustically ~60 cm tall
"high phooey and hystereo" - Yascha Heifetz
Old 25th February 2013, 08:42 AM   #1812
lolo is offline lolo  France
lolo's Avatar
is the height meant to "cancel" the direct sound?
Old 25th February 2013, 10:53 AM   #1813
graaf's Avatar
in no way it can but certainly it reduces the direct to reverberant sound ratio (or more precisely the direct vs ceiling reflected sound ratio)
it seems that a certain ratio is optimal
Old 25th February 2013, 12:07 PM   #1814
graaf's Avatar
another example of a flooder that is a (relatively short) speaker that deliberately uses (and increases the level of) the ceiling reflection and avoids (decreases the level of) the floor reflection to get the sound right - the highly acclaimed Gradient 1.5:
the flooding driver covers the range of 200-2200 Hz, well the tweeter is also aiming significantly upwards, so it falls under the above definition too
more: Specifications Helsinki
Old 25th February 2013, 08:22 PM   #1815
Elias is offline Elias  Finland
Elias's Avatar
Six months ago this was my experimental system: 3 dipoles with FRS8 elements and linear stereo matrix x=0.5
Then a while back I put extra FRS8 in closed tubes and aimed them upwards. I have 3 of them and run them through the matrix. Note that the dipole baffles are still in place but no signal is driven to the dipoles ! I found that the baffles improve the sound of the flooder tubes ! It seems that 2pi radiation is much better than 4pi true omni.
I could say that perhaps good idea would be to place the upwards firing tubes against the front wall. In my room it's a bit hard since my front wall has window and balcony door etc. So I'm using the baffles as virtual walls
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 25th February 2013, 08:28 PM   #1816
Elias's Avatar
Isn't it amazing how small they really are ?
I didn't think about them in terms of flooder before (maybe flooder does not sound enough high class for Gradient ), but indeed the ceiling reflection has a particular effect on the behaviour of this speaker.
Also in my next speaker I'm going to employ upwards tilted tweeter.
- Elias
Old 26th February 2013, 07:14 AM   #1817
graaf's Avatar
it is and it sounds quite like a flooder :
The Helsinkis' sense of spaciousness was amazing. And it was natural in a way that I found difficult to describe.
I paused to listen to a Brahms piano concerto, and thrilled to the strangely great way the sound in my room mimicked that of a concert hall, in a spatial sense.
Instruments had presence in a good flesh-and-blood sense, not in that awful, fussy, typical "high-end audio" manner.
I can better describe what it is that made the Helsinkis' spaciousness so distinctive: I wasn't hearing an airy artifact, but rather the sounds of instruments and voices opening up naturally before me.
Some individual sounds grew, spatially, as they opened up, yet the overall sound wasn't the least bit airy per se. Even as they decayed, the sounds of violins and clarinets had texture.
I'd never before heard anything like it.
from: Gradient Helsinki 1.5 loudspeaker Page 2 | Stereophile.com
The specific area in which the Helsinki 1.5s truly excel is the reproduction of spatial information.
The Helsinki 1.5s not only disappear as sources themselves, they make in effect your listening room disappear from the sonic picture, or at least remarkably close to that.
it is overwhelming and immediate. Music recorded in a large space sounds enormous. Music recorded close up in smaller spaces sounds to that scale. And everything in between is similarly reproduced as it is in spatial terms.
from: Gradient Helsinki 1.5 Loudspeaker | The Absolute Sound
BTW it's quite a pity (and hilariously funny at the same time, as it frequently happens) to see that the exprienced TAS reviewer is so close-minded that he honestly believes that no significant ceiling reflection contributes to the sound of 1.5s!
the midrange is sent to the ceiling at an angle that makes the reflection arrive behind the listener at an ordinary listening distance, while again the high-frequency driver is too directional to reflect off the ceiling to any extent
Would You believe??? Such pure nonsense! Such idiocy!!!
sweet Jesus! have mercy upon us!!
Imagine how stupid a well educated and an experienced person can be when completely blinded by strong preconceptions!
just UNBELIEVABLE!
Old 26th February 2013, 07:51 AM   #1818
Elias's Avatar
You have to reduce consuming those magazines in order to maintain your mental balance
Everyone knows the perceptual effect of ceiling reflected sound, when it is done intentionally and correctly.
How about DIY Gradient instead ? Anyone ?
Old 26th February 2013, 08:26 AM   #1819
Banned
Phantom source elevation? That's what I get. I found side reflections more important for spaciousness.
The tilted Behringers in the following configuration project center sources at about 2/3 of the wall height. Percussive sounds even higher. The toed-out Nathan's work much better.
Old 26th February 2013, 08:38 AM   #1820
lolo's Avatar
ceiling reflections are good, IF they come from the sides, not from the center. Unless you want to kill the stereo separation?
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright 1999-2017 diyAudio
