The Advantages of Floor Coupled Up-Firing Speakers - Page 165 - diyAudio
Old 27th August 2012, 07:29 PM   #1641
Elias is offline Elias  Finland
Elias's Avatar
What we need now is someone explaining to the big masses why the tweeters are not at the ear hight aimed at the listener
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 27th August 2012, 08:40 PM   #1642
graaf is offline graaf  Poland
graaf's Avatar
oh yeah, good question!
is there any Snell's literature on "Type 1" out there?
Old 27th August 2012, 10:18 PM   #1643
speaker dave's Avatar
Originally Posted by graaf View Post
so 2-3 meters? in a typical listening room? are You sure? which frequency band? what is the directivity of loudspeakers used for those test?
I would have ot pull out my RT figures for my room and run the calcs again, but that was my recollection from the last time and also what others have commented on. Your curves with an 8 meter critical distance would be for a large hall, of course.
I have also done draw away response curves from a system in two rooms at PSB. Each curve was divided by the half meter response so it simply showed the response change due to varying room RT and speaker directivity (typical 2-way and typical 3-way tested). By 3 meters the reverberent field (probably direct plus reverberent) had only shelved down by 2dB.
Again, its kind of academic when the ear is so good at pulling out the direct sound.
David S
Old 28th August 2012, 05:57 PM   #1644
Elias's Avatar
David S
I find the whole concept of two channel stereo triangle as an academic excercise since it doesn't work very well in practise
By the way, it's very easy to demonstrate the perceptual weakness of direct sound as it can be overruled by few early reflections arriving several ms later. Looks like Haas effect or the law of the first wavefront should be updated
- Elias
Old 28th August 2012, 06:30 PM   #1645
graaf's Avatar
I wonder how Snell had explained unusual design of "Type 1" and why the concept as such had been discontinued (apart from "Type 1" not being a big seller)?
Old 28th August 2012, 09:30 PM   #1646
Pano is offline Pano  United States
Pano's Avatar
Works great at my house.
Old 29th August 2012, 06:32 AM   #1647
graaf's Avatar
You like it, that's all
scientifically it's a failure based on oversimplificating 19th Century theories of hearing and some hit-and-miss experiments from the first half of 20th Century which (in seeming corroboration of those theories) produced some good enough (...to sell) results
Old 29th August 2012, 07:34 AM   #1648
Colin is offline Colin  United Kingdom
Stereo works OK in ideal circumstances but is something of a compromise. You only have to listen to a good binaural recording over headphones to realise what we're missing.
The BBC are currently conducting experiments in surround and their technical blog reported that four speakers were ideal for producing an immersive soundfield, with little improvement in directional cues if more speakers were used.
They've experimented with the Caldrec soundfield mic for many years.
I don't want to divert a valuable thread off-topic, so here are a couple of links which may be of interest:
BBC - The BBC Radio Blog: Whatever happened to surround sound for streaming Radio?
BBC - Radio 3 Blog: The Festival of Nine Lessons and Carols in surround sound
Old 29th August 2012, 07:38 AM   #1649
graaf's Avatar
I have found a 1981 review of "Type 1", I believe that reviewers had read the marketing literature
it looks like Snell arguments for such design were similar to my arguments for a flooder - complete elimination of the single one worst room problem - the floor reflection - although He argued in terms of frequency domain and tonality whereas I argue in terms of time domain and spatial sound reproduction in the first place
Old 29th August 2012, 07:53 AM   #1650
graaf's Avatar
I believe that the main problem is not of a flawed recording technique but of a flawed reproduction technique
it is perfectly possible to raise the level of realism of reproduction of existing conventional stereo recordings with better - scientifically designed - loudspeakers setups
in other words - one only has to listen to a stereo dipole, for example, because apart from the floor reflection the big problem is stereo crosstalk - Linkwitz seems to understand this when He talks about "Optimizing the Phantom Source without XTC [that is "crosstalk cancellation"] & in a Room":
http://www.linkwitzlab.com/TMT-Leipz...l%20detail.pdf
interestingly, His proposition - the SEL setup ("stereo enhancement loudspeaker": WATSON-Stereo_Expansion_Loudspeakers ) - in his words: "not a CTC scheme, which requires cancellation, but (...) a left and right channel signal enhancement" is essentially quite similar in it's technical effects (increase of the level of the L signal on the left, and of the R signal on the right) to a flooder in Beveridge placement - the loudspeaker setup I have proposed here years ago
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright 1999-2017 diyAudio
