The Advantages of Floor Coupled Up-Firing Speakers - Page 164 - diyAudio
Old 2nd July 2012, 10:47 AM   #1631
I agree... and this may be the root of the problem. I am hoping that a reduction to 2 (or possibly) one unit will suffice to provide the missing ambience. we shall see.
George
Old 2nd July 2012, 11:12 AM   #1632
thanks for reminding me about Jordan. I do have his book buried somewhere, but it is nice to know that he is still in business.
I seem to recall that at the end of his book he discusses a "shelf" of loudspeakers running around or across a room, with many units (his presumably) fed from the left and right channels but with a delay line to stagger the sound. Now that would give a broad sound stage, if the original recording had captured it. I don't know if this ever went into production and I have not heard of it outside of his book
George
Old 2nd July 2012, 09:34 PM   #1633
Colin is offline Colin  United Kingdom
It's mentioned in the article but I don't know if he ever produced it.
Old 27th August 2012, 07:56 AM   #1634
graaf is offline graaf  Poland
graaf's Avatar
from "Acoustics and Psychoacoustics" by Howard and Angus, 4th ed., Focal Press 2009, Chapter 6: "Hearing Music in Different Environments":
Old 27th August 2012, 11:49 AM   #1635
6.283 is offline 6.283  Germany
Hi Graaf,
the ratio of reflected / direct sound and the quality of the reflected sound are very important aspects.
You might be interested in what I have assembled (in writing) about these aspects and some additional ones.
It is a bit lengthy, so again my recommnedation to enjoy it with your favorite beverage/beveridge
What is the optimum polar response of a speaker
2Pi-online.de
Old 27th August 2012, 12:55 PM   #1636
graaf's Avatar
thanks!
I believe this one belongs in this thread:
Originally Posted by speakerdoctor View Post
One of Peter Snell's earliest design, the 'type 1' had the tweeter at the very bottome of the cabinet that included a bottom 'flap' to reflect the tweeter's output. However, that was the end of that approach. Peter later went on to create the Model "A" and the rest is history.
Snell Type 1's
Stig Carlsson referred to this design in His patent application
Old 27th August 2012, 01:00 PM   #1637
graaf's Avatar
some photos
Old 27th August 2012, 02:47 PM   #1638
speaker dave's Avatar
The model A preceeded the type 1. At Snell we referred to the type 1 (affectionately) as "the wheelchair ramp". (It had a shallow ramp leading up to the mid point of the tweeter.)
Not a big seller.
Note that in my testing the critical distance in a typical listening room is about equal to the listening distance. That is, you here direct field and reverberent field in roughly equal proportions. No matter what, your ear/brain is pretty good at hearing through to the direct/early sound.
Be careful when giving credance to RTA curves over direct field measurements.
David
Old 27th August 2012, 06:43 PM   #1639
graaf's Avatar
so 2-3 meters? in a typical listening room? are You sure? which frequency band? what is the directivity of loudspeakers used for those test?
Old 27th August 2012, 07:04 PM   #1640
graaf's Avatar
ps.
again from Howard and Angus:
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 03:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 07:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 01:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 09:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
Copyright 1999-2017 diyAudio
