#1601 | |
#1602 | |
I have recently found an interesting paper by P.W. Klipsch summarizing His extensive tests:
Stereo Geometry Tests excerpt: Quote:
interestingly, larger angles is also what one gets with Beveridge placement, Beveridge was able to propose His own different kind of stereo geometry, taking the speakers out of the corners because of narrow line source characteristics of His speakers in contrast Klipsch was working with highly directive speakers - therefore to achieve the same level of homogeneity He had to put the speakers in the corners with significant toe-in (He advocated around of 45 degrees of toe-in) |
#1603 | |
Isn't it true that Blumlein, the inventor of stereo, suggested +-45 degrees stereo triangle ? Just see Blumlein's stereo microphone with crossed dipoles ! In practise, however, psychoacoustics strikes back, and a hole in the middle can be perceived with too wide base angle. Probably for this reason usually narrower angle is used. I don't know where +-30 degrees comes from ? Maybe equilateral just looks nice ? ![]() - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#1604 | |
BTW have You experienced a hole in the middle with Your pillowed bipolar setup? |
#1605 | |
as to Jordan's linear array system He recommended that the stereo base could be as much as 15 feet wide with very flat loudspeakers wall mounted and toed in 60 degrees so their axis cross well in front of the listener area |
#1606 |
Presumably the 'hole in the middle' disappears once the arrangement comes to resemble a large pair of headphones.
#1607 | |
I wonder what could be the real cause of the 'hole in the middle' then? |
#1608 |
I think the hole in the middle is just the typical loss of the center image when path lengths aren't exact. There is also the question of how much well centered material the recording contains. Classical music with spaced mics might be weak in this area. There are a lot of early pop stereo recordings that use left center and right as the only image locations. They would make a good test (I'm listening to a "Best of Marvin Gaye" these days, which would suit.)
Klipsch was mostly following the recommendations from the Bell Labs experiments that he liked well enough to reprint and distribute. If you must put your speakers in opposite corners then adding a center can be helpful. Note that for a period of time he was advocating a center channel connection that used out-of-phase difference information, until that error was pointed out to him. Even the greats make mistakes. David S. |
#1610 | |
from an article by Alvin Foster:
"high phooey and hystereo" - Yascha Heifetz |
| Floor Standing Speakers. | gurpreetsingh | Full Range | 11 | 12th June 2012 06:42 AM |
| side/ rear firing speakers Good/Bad? | mcmahon48 | Multi-Way | 1 | 6th February 2009 12:28 PM |
| How far can the driver of a down-firing sub be from the floor? | The Paulinator | Subwoofers | 11 | 16th May 2007 08:10 PM |
| Using a diffuser cone for up-firing speakers | tspringer99 | Multi-Way | 15 | 24th January 2006 03:56 AM |
| Woofer: side firing pair vs front firing? | tcpip | Multi-Way | 13 | 9th September 2005 02:13 PM |
