The Advantages of Floor Coupled Up-Firing Speakers - Page 113 - diyAudio
Old 29th March 2010, 02:11 PM   #1121
Banned
Originally Posted by graaf View Post
I agree, no wavefiled synthesis is needed but speakers and the room and the decoder in our heads as a system
This is something that I tend to believe too but in the 80 years of audio reproduction nobody was yet able to describe the necessary framework in an objective way.
Old 29th March 2010, 03:17 PM   #1122
el`Ol is offline el`Ol  Germany
Originally Posted by markus76 View Post
What do you mean by "turned 90"? This is not how multichannel audio works. Upmix algorithms had and have all sorts of problems and limitations, that's why multichannel audio like we know it today was invented (see Toole for more details). The problem is that the industry that would benefit the most from multichannel audio didn't adopt it (yet): the audio industry. The technical platform is there but instead of using it, guys like Key "invent" a "new" upmix algorithm. This will not change things to the better.
With turning 90 I mean that I have one of my ears turned to the middle between the two speakers and the other looking away from it, so that the speakers of a stereo setup become front and rear of the same side. With multichannel I meant 5.1. And what I wanted to say is that mixing between front and rear of the same side has to be very different from mixing between the two front cannels.
Old 29th March 2010, 03:34 PM   #1123
Banned
That's has something to do with how phantom source localization works. Furthermore encoding 4 channels into two results in a loss of information and bad channel separation. Wait for Toole's book to arrive. It should then become much more clearer.
Old 29th March 2010, 03:41 PM   #1124
Just one question:
What is the current standard for panning between front and rear of the same side?
Old 29th March 2010, 03:58 PM   #1125
Banned
We can't localize phantom sources on the sides very well so it should not be tried. Only additional loudspeakers would help. Left and right surround channels should be used for envelopment. Something 2 channel stereo can't provide.
Old 29th March 2010, 04:40 PM   #1126
Listen to Andrea von Salis recordings. Speakers stand in 4 x 90 and ideally front and rear speakers are the same type and driven by the same stereo amp. My percussion CD meanwhile is sold for 69 used at Amazon, but there are demo downloads at their website.
And if Key had a mixing algorithm that really works and would licence it to manufacturers of mixers, that would also be fine.
I heard that in cinemas the center is used for dialogues only. So is panning usually only done between left and right?
Old 29th March 2010, 04:50 PM   #1127
Banned
Doesn't sound like a realistic scenario. Multichannel is here, why try to push a new standard? The music industry is further nullifying itself with that kind of behavior.
There is no "usual". You would have to differentiate between cinema sound and music. Cinema is somewhat standardized (e.g. dialogs mostly from the center channel to get rid of the "stereo seat"), music is just pure chaos.
Old 29th March 2010, 05:23 PM   #1128
Paul W is offline Paul W  United States
Paul W's Avatar
The music industry is further nullifying itself with that kind of behavior.... music is just pure chaos.
So sad, but so true. Optimize a system for one recording only to have a completely different mix in the next recording.
Paul
Old 29th March 2010, 05:30 PM   #1129
Banned
Someone that actually agrees with what I say? That's new
Old 29th March 2010, 05:44 PM   #1130
Of course a new standard like the AVS quadrophonia will never happen. Maybe it would be the standard today if it had been invented in 1960. But it is an experience I didn't want to miss.
What concerns new mixing methods: They are possible within the existing standard.
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 03:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 07:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 01:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 09:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
Copyright 1999-2017 diyAudio
