#1051 |
#1052 |
I had good highs with the HX201 and this guy had insufficient highs with the Beyma, but still the spacial effect he liked. Of course I can not be sure that he had the same effect as I had, but this made makes me believe that energy distribution is not so critical.
#1053 |
#1054 |
@graaf concerning ceiling flooder and "mini wideranger array"
The "phase controled mini wideranger array" could be used to investigate the ceiling flooder approach in a systematic manner. Radiation pattern could be varied from simulating a "small fullranger" a "big fullranger" with radiation pattern narrowing at even lower frequency a "constant directivity" pattern. An adjustable delay for the woofer could be given listeners at hand to adjust a preferable delay dependent from the setting. If the listeners choose no delay, you know that it is not needed. Just a thought experiment. Thought experiments are very cheap unless done real. Last edited by LineArray; 26th March 2010 at 09:16 PM. |
#1055 | |
But if there is an effect different from an omni source it must be due to radiaton pattern ... or has my logic left me somewhere in the depth of this thread ? ![]() Or do you mean spectral energy distribution is not essential ? Last edited by LineArray; 26th March 2010 at 09:25 PM. |
#1056 |
Of course the change of the polar response with changing frequency is important, but what does that have to do with your talk about voice coils and so on?
#1057 | |
to compensate falling VC velocity - which is the reason for falling acoustic power with frequency- by beaming at the listener to exhibit flat sound pressure response. It is like measuring the sound pressure off axis. You get a strongly falling pattern for a t y p i c a l driver. This may rise the need for compensation, when a typical driver is used for that purpose. That is all i want to say. Last edited by LineArray; 26th March 2010 at 09:43 PM. |
#1058 | |
#1059 |
#1060 |
nice!
![]() unfortunately ![]() best,
"high phooey and hystereo" - Yascha Heifetz |
| Floor Standing Speakers. | gurpreetsingh | Full Range | 11 | 12th June 2012 06:42 AM |
| side/ rear firing speakers Good/Bad? | mcmahon48 | Multi-Way | 1 | 6th February 2009 12:28 PM |
| How far can the driver of a down-firing sub be from the floor? | The Paulinator | Subwoofers | 11 | 16th May 2007 08:10 PM |
| Using a diffuser cone for up-firing speakers | tspringer99 | Multi-Way | 15 | 24th January 2006 03:56 AM |
| Woofer: side firing pair vs front firing? | tcpip | Multi-Way | 13 | 9th September 2005 02:13 PM |
