The Advantages of Floor Coupled Up-Firing Speakers
Old 18th March 2010, 07:58 PM   #781
markus76 is offline markus76  Germany
Banned
Originally Posted by gedlee View Post
Flat in room LF response spatially averaged is the key, and only multiple LF sources can do this in a small room.
Sometimes one single subwoofer and a good EQ is all you need:
Best, Markus
Old 18th March 2010, 08:34 PM   #782
gedlee is offline gedlee  United States
gedlee's Avatar
Best, Markus
Markus
There are no hard and fast rules when one is tal;king about LF in small rooms. Every situation is unique.
Earl Geddes Gedlee Website
Old 18th March 2010, 09:01 PM   #783
Banned
Markus
Yes, that's probably the only valid rule. Nonetheless it shows that measurments are indispensable. This is the frequency response with the subwoofer in a corner, downfiring (could be worse):
In corner at ear level:
After EQing:
Lift at 25Hz:
Old 18th March 2010, 09:13 PM   #784
LineArray is offline LineArray  Germany
Default Small (average german) living rooms
Categorization of frequency ranges in room acoustics:
A from 'lower frequency limit of hearing' to
B '1st room mode' to
C 'Schröder frequency' to
D 'Schröder frequency x 4' to 'Upper frequency limit of hearing'
Categories based on:
Michael, Dickreiter: Handbuch der Tonstudiotechnik, Band 1, 6. Auflage,
München: K.G. Saur Verlag, 1997
A: Room pressurization, no wave propagation
B: Modal range
C: Transition range between 'modal' and 'statistical' range
D: Statistical range
Example (self constructed):
Typical Ranges for an average german living room of
Area : 22 m^2
Height : 2,55 m
Volume : 56 m^3
T60 : 0,7 s (lightly to medium damped)
Fs=2000 x (T/V)^0.5 = 223Hz (Schroeder frequency)
Approximate ranges [Hz]:
(lowest mode depending on proportions, here: 5.5m x 4m)
A: _20____62
B: _62___223
C: 223___892
D: 892___20000
892 Hz converts to a subjective pitch of 926 mel
20000 Hz converts to a subjective pitch of 3817 mel
Bark Scale:
http://www.phonetik.uni-muenchen.de/..._5_reichel.pdf
Calculator for auditory units:
Conversion between Hz, semitones, bark, ERB, etc.
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 18th March 2010, 09:24 PM   #785
gedlee's Avatar
Markus
If you think about it, if every situation is unique, then measurements are an absolute requirement to know what you have. Otherwise its just guessing.
Oliver
Those frequencies are all way too high. In my room, and I've measure this, pressurization occurs to about 38 Hz. Then the modal region goes to about 120 Hz and to 200 Hz the modal density is a bit sparse. But 200 - 20,000 is completely statistical. SO in terms of decades, the first decade is mostly modal, then the next two are completly statistical. Thats the way I think about it.
Old 18th March 2010, 09:33 PM   #786
Banned
Which is unfortunately what most people do. The difference is like day and night and still they argue about cables...
Old 18th March 2010, 09:48 PM   #787
gedlee's Avatar
Some people would argue about the sun coming up if you respond to them.
Old 18th March 2010, 09:48 PM   #788
Dear Mr. Geddes,
i know that those frequencies are quite high and this is
for sure not the ideal room for listening.
But it is a kind of room which has to be expected, when
an average consumer sets up his equipment.
Maybe not the average 'high end' consumers listening room of course.
I have observed modal behaviour even in a larger than average
room up to about 360 Hz, there were pronounced local pressure maxima
which could be influenced by changing the position of the speaker.
That room was not too far from cubical unfortunately and
hat rather 'naked' walls on three sides.
Your listening room might be somewhat larger than 'german average'
i suppose and might be treated/damped professionally for its purpose.
www.dipol-audio.de
Old 18th March 2010, 10:12 PM   #789
graaf is offline graaf  Poland
graaf's Avatar
so measurements and equalizers are indispensable
Can anybody recommend any consumer or semi-pro measurement gear?
Are there any consumer or semi-pro equalizers worth buying?
Behringer perhaps?
Or rather there is no escape from computer audio?
"high phooey and hystereo" - Yascha Heifetz
Old 18th March 2010, 10:20 PM   #790
el`Ol is offline el`Ol  Germany
The Behringer DEQ2496 has built-in measurement capabilities. An other alternative worth considering (not as flexible however) is a Sony digital amplifier with room correction.
The Advantages of Floor Coupled Up-Firing SpeakersHide this!Advertise here!
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright ©1999-2017 diyAudio
