The Advantages of Floor Coupled Up-Firing Speakers
Old 17th April 2008, 03:50 PM   #31
graaf is offline graaf  Poland
graaf's Avatar
Originally posted by Graham Maynard
Hi Graaf, and others.
Hello!
Is it not the case that as you walk closer to either LS, its centre beam plus the ceiling reflection of that beam seriously interfere, thus making an optimised listening area very small and narrow?
the question is what kind of LS?
but not only - also logically it is quite the contrary - when You move closer to the speaker, whatever kind, the ceiling reflection becomes more and more delayed and relatively lower in level in relation to the direct sound and thus less detrimental because more delayed and quiterer ceiling reflection less seriously interferes with the direct sound from LS
donít You agree?
I donít question that You can experience such a sound quality deterioration but I cannot find explanation for that
Also what is actually being listened to, the front of cone radiation at possibly 50 degrees plus baffle edge radiation, for much more must go into room reflections than radiates directly ?
this is a very VERY good question!
we should ask ourselves this question - what is sound that we are hearing?
in terms of amplitude vs frequency?
the correct psychoacoustical answer is that it is the energy of the direct sound plus energy of all reflections reaching our ears in the period of around 50 ms after the arrival of the first wavefront, after a sense of the direction of sound (a "sound source") has formed
and this is regardless of kind of loudspeakers because this is how our hearing works
It is a psychoacoustical fact that we never ever listen to something like "center beam of the loudspeaker" - with the exception of the case when we listen to it in an anechoic chamber, which happens not very often
I'm not trying to pick holes or be funny, it is just that I had already tried a loudspeaker (B200 - also shouty) on the floor as suggested and it was so much inferior, especially with regard to the noted ceiling beam interferences.
inferior to what and in what terms? please give more details
perhaps the problem is not with interferences of early reflections but with later reverberation?
When You have a typical audiophile room i.e. a room that effectively absorbs sound in lateral plane (furniture, curtains, audiophile absorbers) and have quite (perhaps even the word "very" would be better) beaming, directional speaker like the Visaton B200 then directing the speaker up to the ceiling (which normally is totally reflecting) DRAMATICALLY raises the level of reverberation in the room
and that can make a BIG difference and can be perceived as "much inferior sound"
Iím quite sure about that
but it is all about being precise and not to generalize too easily from very specific cases
best,
graaf
"high phooey and hystereo" - Yascha Heifetz
Old 17th April 2008, 05:14 PM   #32
badman is offline badman  United States
badman's Avatar
Originally posted by c2cthomas
Oskar Heil Speakers uses speakers that fire up towards the ceiling and an Air Motion Transformer for the HF. http://www.unitedhomeproducts.com/id101.htm
In my Walsh 5 remake I am using the AMT above 5 KHz and an upside down 10 inch Pioneer for mids and LF up to 6 KHz. Below is a sketch of what the final version should look like - if I ever get around to making that version of the speaker. At present I'm considering other adventures which include OB.
Shame to use such a powerful midtweet as a supertweeter. I'd consider cap-coupling it lower, you can mod the pioneer for less top end (cut the wizzer off and add some felt to surface of the diaphragm) and add an inductor if need be.
Oh, and if you haven't tried them yet: the heils are spectacular.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 17th April 2008, 06:32 PM   #33
Pan is offline Pan  Sweden
Graaf... how funny.. I didn't realise what driver you were using. Yesterday I looked after a 8" driver for a small guitar speaker to use with my PodXT and Tele/LP. I arrived at the FE206E as a hot candidate for this project.
I hope it will give a more open sound (due to size and dispersion) than the typical 12" celestion based Vox and Marshalls.
I can imagine your set up giving nice results due to the relative freedom from early reflections. Would like to try somehing similar some time. My current rooms are either to big or small for such a set up though I believe.
/Peter
Old 17th April 2008, 08:13 PM   #34
Graham Maynard is offline Graham Maynard  United Kingdom
R.I.P.
Graham Maynard's Avatar
Thanks for the reply Graaf,
Still thinking, and will cost me nothing to try again !
Cheers ....... Graham.
Old 17th April 2008, 08:31 PM   #35
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Graff - you might find this design of interest http://gr-research.com/index.asp?Pag...ROD&ProdID=113 plus there are a couple of other similar upward firing designs at that web site. Just food for thought as to what can be done with a DIY type of project. Combined with some room treatments some very good results should be obtainable.
badman - I use my AMT 1's for HF because that is what that particular design was specified for. Also the AMT-1's can have a bit of a nasty rise at around 3.5 KHz that would take a notch to filter out and I wanted to keep the XO simple (like me ) These are the older models (1970's) and I would not want to get 'em lower than 1.5 KHz - but they are "sweet" - loved them since the '70 when I 1st listened to them. On my 2do list is buying some of the new replacement diaphragms and coming up with a new magnet arrangement that more refined than the old design. Sorry for the OT -
DIY audio can be expensive Ė but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 17th April 2008, 10:58 PM   #36
Bratislav is offline Bratislav  Australia
Originally posted by Pan
I have done a lot of these tests in various acoustics and with various sources of sound. I write and record music, sometimes with a friend that also is a musician and use to produce music/radio jingles. We have recorded in rooms the size of a bedroom up to hangar sized halls. Building/arranging studios and listening rooms from 10 to 100 meter squared we have had great opportunity to test the room sound and localization of sound sources in close to anechoic to lively acoustics in the same room.
Without this ability our ancestors would have been tigerfood and we would not exist.
/Peter
That is the point - we don't need to localize the tiger to within 1m at 20m distance. Just a general direction. Our hearing is not designed for such precise localization (just compare design of bat's hearing apparatus and ours and differences will be rather obvious).
I go to live concerts on average twice a month (mostly classical, but some jazz - which is often amplified so it doesn't count).
I often try to listen with eyes closed (that is my "training") and without visual feedback I often find it impossible to identify which instrument is playing a particular line that I hear even if they are wide apart (e.g. woodwind section is usually spread over a whole back row). Try it next time - close your eyes and guess. You will be surprised.
Old 18th April 2008, 01:59 AM   #37
Well as I mentioned I allready have made that many times, no surprises.
Now when it comes to woodwinds (I play woodwinds myself) those may be harder due to the relative non-transient nature. Also many sources of the same type tend to mix and become diffuse. What I allready wrote is still true and valid.
Obviously it becomes more diffuse and hard to pic the localization of individual instruments when the whole orchestra is going FFF.
/Peter
Old 18th April 2008, 11:12 AM   #38
graaf's Avatar
/Peter
Actually the method of dealing with early reflections I proposed above permits to achieve in a room of a given size results completely unachievable in a standard set up.
For instance:
Letís assume stereo basis (distance between the speakers) of 3 m, which I consider as minimum for realistic reproduction, and a typical equilateral stereo triangle set up
In such a case the loudspeakers should be at least 1.4 m away from the nearest wall so that the first wall reflection would be delayed by 5 ms, which is considered bare minimum to avoid its detrimental effect.
It means quite a big room and dedicated exclusively for audio, because I somewhat cannot imagine a woman letting her partner to move a loudspeaker 1.4 m into the living room
And Dr Geddes writes that actually the required delay is 10 ms to avoid the detrimental effects of early reflections
To achieve that result one really big room would be required, because the side walls would need to be about 7<8 m apart for that (assuming the absolute minimum stereo basis that is only 3 m wide!)
And also the front of the loudspeakers should be about 2 m away from the wall behind them.
Assuming that the listener is seated next to wall behind him (probably not very good idea but letís assume) a room of 40 square meters dedicated exclusively for audio would be needed to satisfy the 10 ms delay of early reflection from side walls and back wall requirement. And what about ceiling reflection and the worst - floor reflection? We can possibly have a very high ceiling but floor reflection is inescapable with conventional speakers even in a very big listening room.
Listening room of 40 square meters dedicated exclusively for audio - quite impractical Ė isnít it?
Not many music lovers could afford something like this. That is why people look for different solutions which aim at lowering the level of reflected sound like using reflection absorbers/diffusers but this devices also have no WAF at all and are not suitable for normal living room.
Another method of lowering the level of reflected sound is to control directivity of spekarer using waveguides as in Dr Geddes designs. Unfortunately the waveguides and matching woofers ought to be quite big to do the job. And resulting speakers are not very decor-friendly, quite visually obtrusive. And even in their case they ought to be moved away from walls and into the room! (please correct me if I am wrong)
In the set up I proposed only a room of about 25 square meters and a ceiling of about 3.5 m (or less if we move closer to the speakers) would be required to achieve the 10 ms early reflectionís delay. And absolutely no problem with floor reflection.
Moreover the speakers are to be positioned against the walls and only 20 cm above the floor Ė it means no WAF and home dťcor concerns at all, the speakers are practically invisible.
All that is required is:
- relatively free space around the speakers, that is no big/tall and/or sound reflecting furniture especially on the side walls (cupboards, tall bookcases etc., fortunately such a big and tall furniture is not characteristic for contemporary home decoration)
- listenerís seat to be located symmetrically with regards to speakers, which is a standard requirement for stereo reproduction and the sofa can be just moved to the right place for serious listening - no problem at all
best,
graaf
Old 18th April 2008, 02:16 PM   #39
What can I say.. you cover it up nicely!
Some thoughts..
The floor reflection can be dealt with by using an array or with conventional speakers a table can be placed close to the listener to shadow the reflection (effective in the higher registers at least).
About the stereo triangel.. have you tried other angles? 22-23 degrees use to give best results for me with boxes and open baffles.
My solution?
I bought a house so I can go crazy with a dedicated room, big if needed.
/Peter
Old 18th April 2008, 05:34 PM   #40
thinkbad is offline thinkbad  Denmark
thinkbad's Avatar
graaf, extent your idea even further.
Place LS in the corner, normally the worst possible position for a conventional speaker. Now, you get even more boost at low freq and your 2 walls and the floor can be assumed to be a BIG baffle, and at the same time the adjacent walls are as far away as possible.
Maybe a Visaton B200 stuck deep into the corner without enclosure or even baffle. Suspend the driver from the ceiling or mount it to a backbone of some sort. Stuff the walls next to the speaker and drive it with a transconductance amp.
Well, just an idea
JB
The Advantages of Floor Coupled Up-Firing SpeakersHide this!Advertise here!
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
