The Advantages of Floor Coupled Up-Firing Speakers
Old 24th March 2014, 03:38 PM   #3191
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by TNT View Post
I use the Bremen speakers and they are superb. But not as depicted in the photos on a front wall but on side walls.
there was a picture posted earlier in this thread by myself of Bremen speaker in a sidewall placement:
It may seem wide but works very well. No hole in the middle but great stage. Walls disapear. Orchestra is grand. Tight close-mic'd recording sound... close, but not dead.
No hint of speakers on most recordings.
The music experience this system provides is exciting and involving. From Emma Kirkby, via Keith Jarret and Pink Floyd to Meshugga
The big things started to happen when speakers came onto the wall. This was a revelation.
this is how the sidewall/Beveridge placement works
thanks for sharing Your observations!
"high phooey and hystereo" - Yascha Heifetz
Old 24th March 2014, 07:24 PM   #3192
TNT is offline TNT  Sweden
Oops, yes, that is how I have them. But considerably farther from the back wall.
Old 24th March 2014, 09:21 PM   #3193
graaf's Avatar
the farther the better
Old 25th March 2014, 11:19 AM   #3194
daniel is offline daniel
'Soffit' mounting speakers is a good way to get rid of early reflections. Putting them in the sidewalls in a long-narrow room is as good position as any. Danley-style horns come to ming for that application. Just make sure that no detrimential signal comes from the front wall reflection, if the speaker is more omni.
"Later James experimented with Dr. Floyd Toole’s side-firing ambiance theories, which led to Late Ceiling Splash (LCS)."
LeJeune's and Romeirin's 'ceiling splash' is a clever way to get a good clean ISD gap with a very dense 'reverb tail'. Only caveat is that it is not laterally arriving. Aiming the directional 'reverb' speaker to the sidewall gets you the 'lateral' part, but depending on the room, doesn't give enough signal delay gap. Thats why it is what it is.
Next evolution of the theme could use a DSP to delay the 'effect' speaker to make the later arriving soundfield more dense and arrive more laterally... wait, since Dolby surround every upmixer can do this. Another case of "Ancients keep stealing our inventions".
Old 25th March 2014, 06:51 PM   #3195
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
^Yes this wheel has been invented already - Dolby Prologic (II) encoding! Most AV receivers have DPLII and many parameters are adjustable, eg. surround/rear speaker distance/delay/phase warp.
Dolby Pro Logic - Wikipedia, the free encyclopedia
AINOgradient speaker project
Old 25th March 2014, 11:38 PM   #3196
Bech study referenced but not linked as far as i could find...
http://orbit.dtu.dk/fedora/objects/o...317430/content
Old 11th July 2014, 07:45 AM   #3197
graaf's Avatar
meanwhile up-firing speakers conquer the realm of HT:
http://www.youtube.com/watch?feature...sAsZyRm_k#t=45
Old 11th July 2014, 08:05 AM   #3198
graaf's Avatar
...and a really cute little reporter visits Mr Hiroyuki Yoshii - who went from big waveguides in the 80s (which can be seen in the background around 0:25-0:30) to diminutive up-firing speakers in the 21st (long vertical tubes behind "Mr Time Domain"):
???????? - YouTube
Old 12th July 2014, 04:46 PM   #3199
Elias is offline Elias  Finland
Elias's Avatar
ONKYO - What is Dolby Atmos? - YouTube
I cannot see any up firing speakers in that Onkyo commercial
BTW, Onkyo did make some interesting speakers in the past:
Of course it is not floor coupled nor up firing, but horns and high efficiency. But hey that's exactly what Mr Hiroyuki Yoshii did too
And now they are into up-firing
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 12th July 2014, 11:14 PM   #3200
graaf's Avatar
? 0:44?
The Advantages of Floor Coupled Up-Firing SpeakersHide this!Advertise here!
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 03:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 07:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 01:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 09:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
Copyright ©1999-2017 diyAudio
