The Advantages of Floor Coupled Up-Firing Speakers The Advantages of Floor Coupled Up-Firing Speakers - Page 252 - diyAudio
Old 14th May 2013, 11:20 PM   #2511
fas42 is offline fas42  Australia
Banned
Originally Posted by Pano View Post
For practical and budget reasons multi-channel is the way to go and works great. Pure stereo can do it, but it takes space and money to get the effect.
There are a number of ways, the ear/brain is very forgiving if you give it the right ammunition. Personally, I've found space and money to be unnecessary, focus and fussiness in refining every link in the chain of an otherwise conventional system will also succeed, the only disadvantage of the latter will be that there is a hard limit on the peak level of sound because the voltage rails of the amplifier will not be large enough.
Old 15th May 2013, 06:55 AM   #2512
graaf is offline graaf  Poland
graaf's Avatar
ps. Ad:
Originally Posted by Soundtrackmixer View Post
So it is not just reflections in general, it is reflections with a time component coming from specific directions.
Originally Posted by graaf View Post
this is my point exactly
What do You think - which is better for audio quality - an incoherent reflection delayed by ca 2.5 ms or a coherent one delayed by ca 6 ms?
not only twice as much delayed but also 6 dB quieter (propagation loss) for the same reason which is sound path being twice as long
"high phooey and hystereo" - Yascha Heifetz
Old 15th May 2013, 09:49 AM   #2513
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
I don't know at what size this starts to kick in. My listening room is about 3400 cu ft and it's not big enough. I have heard the effect starting in rooms that I would guess at about 5000~7000 cu ft. Wish I knew where the tipping point is, if there is one.
In HiFi shows of the past it was common to have a live band play in an auditorium. The musicians were recorded and replayed over loudspeakers in the same auditorium. This used to be a very convincing exercise. Why? Because the replay could use the same room acoustics as the original.
Most of us don't have a problem with the "girl and guitar" reproduced at home. It fits in our rooms - even if it is "she is here". It becomes a problem if the recorded room acoustics differ too much from what we have in our listening space. I believe that listening to larger ensemble recordings in larger rooms is more convincing simply because of this better fit of recording/reproduction room sizes.
Rudolf
www.dipolplus.de
Old 15th May 2013, 10:01 AM   #2514
markus76 is offline markus76  Germany
Banned
Correct and that's why the sound reproduction concept "speakers working as instruments" is pretty limited. Multichannel on the other hand can bring large room acoustics into small rooms.
Old 15th May 2013, 11:19 AM   #2515
graaf's Avatar
not just multichannel because :
When the listening room provides artificially added reflections, the presentation can become more "you're there". It's like the front wall of the listening room has been removed and opens into the auditory space of the recording.
not for the first time I can see contradictions in Your posts
Real envelopment (LEV) requires additional speakers at the back. The effect is profound and nobody that has heard it would ever argue about the superiority of multichannel over stereo. Obviously a lot of people here haven't heard good multichannel setups/recordings.
LEV is an important factor in QUALITY of auditoria but even then NOT of all of them:
Leo Beranek's paper "Listener Envelopment LEV, Strength G and Reverberation Time RT in Concert Halls" 2010:
In all of the non-shoebox halls, the audience seating extends nearly to the ceiling on one or more of the four sidewall surfaces. Thus, energy is removed there before the reverberant field is established
LEV per se is not a requirement for realism whereas ASW/spaciousness is such a requirement
Old 22nd May 2013, 09:45 AM   #2516
graaf's Avatar
BTW a question - do available multichannel formats allow for perception of ASW ie. the spaciousness of sound sources?
Old 22nd May 2013, 10:49 AM   #2517
Baseballbat is offline Baseballbat  Germany
And the multichannel setup makes the small room even smaller...
Don't get me wrong, I would always recommend a multichannel setup. But the reality, at least in Germany, is: too many people can not place 5 good speakers + subwoofers in their room. They eat up too much space, and although the user might have a great listening system, he has no more space to live. People interested in multichannel ("surround") often bought very small speakers to put on the wall, and that was OK for movies, but definitely not OK for hifi audio.
That is one reason why multichannel audio is nearly dead. Other reasons include the manufacturers, which still think that "multichannel" is a synonym for "home theater" and offer only such speakers. And the electronics is Stereo, too, except of those big A/V amps offered by japanese companies, which are never even considered as an alternative in the HighEnd world.
Old 22nd May 2013, 11:40 AM   #2518
Banned
Why would on-wall not be okay for HiFi? I think that was and is a missed opportunity. But don't get me started on how marketing ruined HiFi...
Old 22nd May 2013, 11:58 AM   #2519
graaf's Avatar
I agree and the situation is not going to change for the same reasons that You have stated
but as You say:
then question is whether a multichannel setup really has any advantages over 2 channel as far as realism of sound reproduction is concerned
or perhaps it is all just about some impressive effects?
just to quote Peter Walker's of QUAD opinion on multichannel:
It's just that you don't need these sounds in the back, they're not musically very interesting.
the opinion referred to the multichannel of the 70s ie. quadrophony, of course, but it's a general statement and I think that it holds true with regard to any rear channels
Old 22nd May 2013, 02:55 PM   #2520
DrDyna is offline DrDyna  United States
DrDyna's Avatar
but as You say:
Wiring two rear channels in series with the positive terminals of the amplifier can be fun sometimes
The Advantages of Floor Coupled Up-Firing SpeakersHide this!Advertise here!
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Copyright ©1999-2017 diyAudio
