The Advantages of Floor Coupled Up-Firing Speakers
Old 13th March 2013, 12:52 PM   #2121
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by Elias View Post
None of those links describe the frequency range of the floor reflection that affects the distance perception.
perhaps it is just the same range that generally affects spatial perception - 0.4<4.0 kHz
we don't know of course
but until we know I can't see any reason to exclude the lower midrange a priori
"high phooey and hystereo" - Yascha Heifetz
Old 13th March 2013, 01:23 PM   #2122
Elias is offline Elias  Finland
Elias's Avatar
That is your assumption. I assume it happens above 1kHz
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 13th March 2013, 01:29 PM   #2123
graaf's Avatar
that's ok let's call it hypothesis
I gave a foundation for my hypothesis - about 0.6 ms/20 cm, You remember?
So please give any for Yours
Old 13th March 2013, 02:37 PM   #2124
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
I am trying to understand the results of Elias' test
Without any added data I only see a subjective description (can't be anything else). I don't dare to take any conclusions from that (and wouldn't call it "results" either).
it is clear that with 400Hz low pass and also 700 Hz low pass the shifting effect is not that severe - perhaps because ....
just a hypothesis
I would support your argumentation
www.dipolplus.de
Old 13th March 2013, 02:55 PM   #2125
markus76 is offline markus76  Germany
Banned
Rudolf, you got PM.
Old 13th March 2013, 07:05 PM   #2126
ScottG is offline ScottG  United States
Are You sure?
Isn't it that for a reflection of a wave to occur the reflecting surface must be no closer than a quarter of a wavelength from a sound source?
What you are describing is a resonant condition - and usually that doesn't happen for a discreet freq.. Now increase that to a pass-band and yes, there could be a *reflective* interference that would change intensity somewhere along the pass-band. An extreme example of this would be an un-damped transmission line (with "peaks" and "depressions" in intensity along the pass-band).
perspective is everything
Old 13th March 2013, 07:30 PM   #2127
graaf's Avatar
but a standing wave between two walls happens at a discreet frequency, doesn't it? And it is simply a reflective condition not just "a *reflective*"
Old 13th March 2013, 08:18 PM   #2128
Elias's Avatar
Originally Posted by lolo View Post
Obviously one is missing, no floor, no ceiling pads. silly me.
I see So without any absorption the first reflection is something like -3dB ?
Old 13th March 2013, 10:08 PM   #2129
Typically not - and least not in relation to a discreet freq.. (..most conditions are simply to complex. That's not to say that there might not be some interference to that wavelength - but that's a bit beyond my interest.)
The point is that it's not really a Reflection.
In any event, we a getting a bit "far a-field" here.
Getting back to a timing que from a more empirical perspective - lets look at the condition for an echo, and derivatives from there..
An echo is a reflection, and an apparent one at that (..in other words a reflection that can be described as a separate source of sound). With that in mind, is a lower freq. echo more easily located at the earliest point (distance/time) that it becomes an echo/(apparent) - or at some multiple of that distance/time?
Now consider a low freq. reflection that doesn't have the distance/time to become an echo (or apparent). Under this condition we have the precedence effect - the direct sound dominates and you get a single localized cue. Of course IF the reflection is sufficiently intense you'll get an alteration to that localization effectively moving the source location a bit closer to the point of the reflection. (..note: this can and does happen in rooms at freq.s below 400 Hz - even in a stereo reproduction context: ex. "pushing" images forward like drum-kits and foreshortening depth as the rear of the loudspeaker gets closer to the "front" wall.) With this in mind, will a closer low freq. reflection have more or less effect on a source's position?
With respect to distance/time and reflections - are the results similar?
Finally lets look at simply the onset of a lower freq.. (or a minute portion of that wavelength). Let's disregard the nature of a reflection vs. that of a resonance. Further, let's disregard the primary condition of the precedence effect.
Just looking at distance/time for our onset to a particular lower freq. wavelength, and factoring-in answers to the questions above, will a really near distance/time reflective condition to our wavelength have much effect?
(..Note: I'm not saying/suggesting the onset of the direct sound doesn't have effect, but rather will a very near distance/time reflective condition to that onset have a substantial effect?)
Old 14th March 2013, 11:33 AM   #2130
graaf's Avatar
most probably not - not substantial - but also most probably highly depending on the program material
and I ask why not
because only if we know why we can say when it can happen and only the we can consciously take it into account in the loudspeaker design
The Advantages of Floor Coupled Up-Firing SpeakersHide this!Advertise here!
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 03:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 07:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 01:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 09:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
